Speaker access
Old Aug 25, 2002 | 06:41 AM
topsy's Avatar
Question Speaker access
I was looking at gaining access to the rear speakers, and looked at a service manual. It appears that all the panels are held in place with push pins, except for one or two hidden screws?
Is it very difficult, or kind of a pain?
Old Aug 25, 2002 | 07:47 AM
Fast Gator's Avatar
It really very easy. Just use a small pick to "pull" the center of the push pins out, then remove the outer "ring" of the pins. You must also remove the rear storage box, I forget if its screws or bolts, but their in the bottom, you can see them
Old Aug 25, 2002 | 07:59 AM
SLVRLTNG's Avatar
thanks, I learned the hard way...if you push the push pins in they go all the way thru and into the bottomless pit... ........JR
