HELP!!! Engine trouble!!!
Old Aug 14, 2002 | 08:16 PM
tallimeca's Avatar
Engine is shuttering badly while idling. Bad shutter around 1200-1800 rpm's. Feels like it's about to stall any second while driving. Started the other night while driving home from work. Went through everything i could think of today. I put everything back stock except the electric fan and water pump. No way i'm tearing into that again. Took out the chip, put everything oem and still does it. Reset the computer no change. No engine lights no codes stored. Looks like my truck is going to the dealer rather than ford fun weekend. I'm so depressed
Now, if there was an engine misfire or a coil pack gone, would that trigger a code.
Do you think there will be any warrenty hassel with the electric fan and water pump?
Old Aug 14, 2002 | 08:26 PM
Litenin75's Avatar
Check your plugs. A fellow lightning owner here in Memphis went through a shuttering problem and found a plug that was fried. Do this ASAP.
Cory
Old Aug 14, 2002 | 08:38 PM
StruckBy99's Avatar
I had a rough idle that shuddered once in a great while.
Found out that oil was built up around the butterlies of the throttle body not allowing them to close completely. This was with only 2300 miles on the truck!!! Took the throttle body off, when I had the upper ported, and cleaned it with a wire wheel on my dremel tool. That crap did not want to come off!!!!
Truck idles like stock again, even with 4#pulley, chip and DensoIT22's.
Take a look behind the butterflies of your throttle body!!
Hope this helps,
Jason
Old Aug 14, 2002 | 08:55 PM
Don's Bolt's Avatar
Yo Don
Call me
I left a message on your cell phone
If you still have the stock plugs we can swap them out with some TR6's I got a spare set.
I bet that is the problem
Old Aug 15, 2002 | 01:56 PM
Don's Bolt's Avatar
Thumbs up UPdate
I just got back from tallimeca's house
We replaced a coil pac and a spark plug and it is running normal again. Now hw just has to put his mods back on, and he will be all set for FFW this weekend.
Old Aug 15, 2002 | 01:59 PM
SLVRLTNG's Avatar
Way to go DON, you're not gonna help Don re-install his MODS??? what a bud........... JR
Old Aug 15, 2002 | 02:09 PM
Don's Bolt's Avatar
Originally posted by SLVRLTNG
[B
Way to go DON, you're not gonna help Don re-install his MODS??? what a bud........... JR [/B]
Nope, screw him, LOL
He is on his own. J/K
It was just to damn hot out, and he had to get to work.
Plus I have work to do on my truck.
This was the 2nd Lightning that I fixed this week, and still haven't touched mine.
tallimeca's Avatar
Yes!!!!!
I'm back in buisness!!! Pulled the wires off the coil packs one by one this morning. Found the number 8 cylinder made no difference when pulling the wires. No ford dealers had them in stock so i got one from napa-$49.00. It is exactly the same as stock.
Don C came over and gave me a hand. We are back. I think i'm gonna throw a whole new set on anyhow just in case. I've said it before and i'll say it again. Don (Don's Bolt) is a top shelf guys a we're lucky to have him in our community. He's helped me out on several occasions!!! Thanks again bud. I owe you.
**** NOTE-when attempting to remove plugs, make sure to lube the rubber insert in the plug socket so they don't get stuck. Don't attempt to use magnetic reatch magnets to remove extensions and sockets. The magnet is stronger than the adhesive and the magnets come off and get stuck between the head and the plug socket. Bad news. But we got it out.!!!
Old Aug 15, 2002 | 02:18 PM
tallimeca's Avatar
hey hey hey
we were in the shade and i had my fan out there so it was only like 98 instead of 105....hehehehe
Don't forget i let you use my grinder to customize your wrench and pry bars to bend up your fire wall. By the way, Don isn't into appearance mods unless you like scratch and pry marks all over a brand new blower!!!!
Old Aug 15, 2002 | 02:23 PM
PT's02L's Avatar
StruckBy99 -
Just a thought - the T/B butterfly has a coating on it from the factory. I have no idea what it is or what purpose it serves. Now that you've removed it, you might inquire has to purpose.
Old Aug 15, 2002 | 02:26 PM
Tiamat's Avatar
Yeah baby!
Old Aug 15, 2002 | 05:23 PM
StruckBy99's Avatar
PT's02L
This wasnt a coating. It was on the throttle body bore and a little on the butterflies. It was almost like soot that built up behind the butterflies. It was thicker in some spots than others and was a PITA to get off.
Jason
Old Aug 16, 2002 | 12:37 AM
Don's Bolt's Avatar
Thumbs up
Hey Don
Does anything look differant in this pic????
Old Aug 16, 2002 | 12:41 AM
BadAzz516's Avatar
Rest In Peace
Wink
Originally posted by Don's Bolt
Hey Don
Your missing your fan shroud plastic .
Old Aug 16, 2002 | 12:50 AM
tallimeca's Avatar
no
i'm missing something, besides the fact that it looks like a white truck and not a silver..........and obviously it's not the eaton blower...... i'm stumped
