HELP!!! Engine trouble!!!
Old Aug 16, 2002 | 12:55 AM
tallimeca's Avatar
blower
not sitting as high, or the intake rather.....not as high as before??? Damn it, i need to know, it's driving me nuts.
Old Aug 16, 2002 | 12:56 AM
Don's Bolt's Avatar
Re: no
Originally posted by tallimeca
i'm stumped
I re routed the intercooler hoses, to where they were ment to be.It even runs cooler now.
Here is the before pic
Old Aug 16, 2002 | 12:58 AM
tallimeca's Avatar
aha!!
weren't they under the blower snout on top of the coolant house??
Talked to Kyle today and they are gonna do my pulley saturday.
Got my stuff from LFP, except my shackles aren't here???? Now i gotta track those down
Old Aug 16, 2002 | 01:46 AM
BfB's Avatar
BfB
Banned For Rules Violations
Re: hey hey hey
Don't forget i let you use my grinder to customize your wrench and pry bars to bend up your fire wall. By the way, Don isn't into appearance mods unless you like scratch and pry marks all over a brand new blower!!!!
So I was right in my thinking that the works blower is so close to the firewall that it may hit when the engine is under torque load?
Old Aug 16, 2002 | 01:51 AM
tallimeca's Avatar
it does
it did in fact contact the fire wall, but only when in reverse.....go figure. I little friendly persuasion fixes everything.
Old Aug 16, 2002 | 10:26 AM
Don's Bolt's Avatar
Re: Re: hey hey hey
My unit is a pre production prototype, Chris has since changed the Casting to fix the clearance problems. He has also changed the Boost Bi pass actuator to fix one other little problem I found.
He sent me a new peice that I installed last night, and that should make installing it a lot easier.
New position of boost actuator
