Stock oil pressure gauge
I know there was rumble a while back about trying to convert the stock oil pressure sender into something that actually worked.
Has anyone done it? Does it work? It would be nice not to blow a gauge pod on something that is already in the dash...
Coldie
Coldie
I remember the '96 Cobras you could do this on, but I believe from '96.5 on up or either '97 on up you couldn't because of the gauge cluster electronics had been changed. Even on the '96s you had to solder a specific diode, I believe, on the back of the factory cluster as part of the steps to making it work.
