Mac Exhaust Installed!
Old Aug 11, 2002 | 02:00 AM
lightning00n93cobra's Avatar
Just installed mac's new exhaust on the lightning. Took me about 45 minutes without a lift. Fit is excellent and sounds bad azz! For the money you cant beat it. Nice big shinny tips to. I would reccomend this kit to anyone.
Old Aug 11, 2002 | 05:18 AM
Flying Mofo's Avatar
Banned
Damnnn, youre running 16 PSI through that stock block? How many miles do you have on that combo?
Old Aug 11, 2002 | 06:05 AM
Rob_02Lightning's Avatar
He should be running way more than 16 Lb's. Mine was running 9 stock, up to 12 with just a hi flow ram air filter, then with the Upper Pulley, Chip, and By-Pass it took me to every bit of 13-15 Lb's of Boost. My guess is he's up around 20+.
Old Aug 11, 2002 | 07:07 AM
Fast Gator's Avatar
Where are you getting these reading? If its the stock gauge, they are somewhat optimistic in its reading
Old Aug 11, 2002 | 07:59 AM
wantalightning's Avatar
Hey, did you make sure you tightened the bolts. These exhausts are known to fall off when you install them half drunk at 3 in the morning.
Old Aug 11, 2002 | 10:06 AM
wantalightning
Hmmmm where did u get that info? Sounds like you were at my house during the install...... I wonder who you are lol
8 Pound lower and stock upper I dont have a aftermarket gauge so dont know. But yes it is the stock bottom end. 18k Everything will be fine. ( knock on wood)
Old Aug 11, 2002 | 10:54 AM
99REDBOLT's Avatar
Thumbs up
i have # 8 lower and a # 2 upper on my 99 and it is stock also.
mine shows about 17 pds of boost on the gauge. i think the upper may be good for about 1 pound.
Old Aug 11, 2002 | 11:53 AM
TYT-LYT's Avatar
lightning00n93cobra,
Where did you get your kit from and for how much?
Old Aug 11, 2002 | 05:14 PM
I got my kit from JL. It was 300$.
Old Aug 11, 2002 | 05:20 PM
RTKILLA's Avatar
you might think that but do you realize that a 8lb lower is much larger then a stock lower that the 2lb upper is rated for?
So you running about a 4 to 5 lb upper with that larger of a lower pulley.
