How Do I Stop This Beeping Noise!!!
Some one explain to me the process of stopping this seatbelt chime from going off besides..........
Buckling my seatbelt
Pushing the red button on the seat belt latch
I hate it...
Matt
I hate it...
Matt
The instructions are in your owner's manual. I don't remember off the top of my head... Something about turn the key to run, buckle the seat belt and unbuckle it 3 times, turn you lights on and off (do all this in like 5 sec.) and the ringing should stop. Check the manual to make sure the process is right though.
It's in your owners manual. If you dont have that I can try to explain it to you later but its a P.I.T.A. Its something like turn your key to the on (dont start the engine) position wait for 2 minutes till the seatbelt light goes out, then plug and unplug the belt 3 times, after that turn the headlights on and off then plug and unplug the seatbelt 3 more times, and that should do it. The seatbelt light is supposed to flash fast a few times to tell you its disabled.
R U GUYS SERIOUS??
This is some scheme to get me to go try this while your at your computer laughing!!!!
Thanks Spank..I will check the owners manual and print your email
and try!!
Thanks again
Matthew
and try!!
Thanks again
Matthew
Go here it is crazy stuff they are telling the truth its like turn this off but not before you do this then do that and by the way you only have 2 seconds to complete or you do it all over again the over all process looked to me a while ago to take a while. So i said screw it and buckle up =]
Later.....
Later.....
Yeah if you think thats crazy just don't ever loose one of your keys or you'll look like clown trying to program a new one!
You can also just push in the release button everytime and that will stop it from beeping until you start your truck up again.
When you get in your truck, start it up then push the red seatbelt button as if you are unclipping the seat belt(even though its not clipped in.) Simple...works for me every time. But its still better just to buckle up.
Later.
P.S. Or you can do what RTKILLA said...lol...same thing.
Later.
Do the trick (took me 2 tries) then the beeping goes away, and if you are a safety nut, wear a seat belt...
The process is in the owners manual... there is also a process to turn off the auto-locking feature if you so desire...
I hate the seat belts on Fords... they lock up on acceleration too easily... then I get squished to the seat and have to compress my rib cage to unlock the belt...
to give some breathing room, like Chevy and other GM's ...
<Click and STAY, dammit!!!>
