Long Tubes and Cats ??
Somebody help me here...
Why would I need to buy a whole exhaust system? Couldn't I get the same effect from installing long tubes and say, Bassani high flow cats? Any comments and opinions appreciated.
the header's help alot for flow ! but thew mufflers are what's guna hold ya back.... check out www.teamjdm.com their is a full header to tip system wich will save you some cash !
Well, it would be a little different, but not a huge one. Lightning exhaust was pretty good unless you're packing on the boost.
ILL_SVT,
You can do half at a time.
Our long tubes and high flow cats will bolt right up to stock muffler or you could do the catback and it will bolt up to you stock cats.
The stock muffler is good all depending power level.
With our catback you will gain 9 to 11 HP over the stock catback.
So there is some restriction in a stock system.
Hope this Helps
Jim@JDM
Hope this Helps
Jim@JDM
