tire wear
Old Aug 8, 2002 | 02:53 PM
$umtoy's Avatar
Post Tire wear
I have had my 01 in two alignment shops in the two past days. they work from 12:00 to 6:30 yesterday and about 2 hours this moring. I had outside wear on the left and inside wear on the right. The shops could not find eneything wrong with the truck. It will pull to the left if you let the wheel go. They said the washers & cam bolts would not help. The Ford dealer called SVT and the national tech. line for a opinion. They will let me know and I will post it. I have 10K on my tire and the back looks almost new and the front will have to be chaned sone. Real sone now that I put them on the back and added mods from JLP.
Old Aug 8, 2002 | 03:16 PM
Cali L's Avatar
I had the same problem the first go round at 15K. The front tires were trashed the same way. The dealer I used back in Colorado had to remove some factory alignment stops to get the thing aligned (cost twice as much). All I know is the new set has 15K on them and the fronts are wearing even.
Old Aug 8, 2002 | 04:12 PM
DEIMATT's Avatar
Does anyone in here rotate their tires everytime?? I wonder with moderate stomps if this helps alot??
Matt
Old Aug 8, 2002 | 04:52 PM
robstaxi's Avatar
I also have had problems with my alinement. I have taken my truck in 4 times for alinements about 1in on the inside front is wearing my truck has the roush supention kit...can't seem to find the reason why this is happing at 50,000 km I had the 2 upper ball joints replaced a cam bolt and washers witch was striped at the dealership had just put in 2 new tie-rods and the truck still pulls the the right..on the left front the seems to be alot more wear on the inside front there ...there is a little section on the inside tire that has worn till it was smooth and the rest still had some tread left...can anyone stear me in the right direction in fixing this problem...buy the way the tires on my truck are GT EGALE II 275 70R 17's now I have 73,000 km on my truck and the tires have been rotated regularly I have pics but I don't know how to bot them on
Old Aug 8, 2002 | 05:07 PM
Drkone's Avatar
This sounds like a fairly common issue. I thought I was the only one.
I too took my 2000 to three different places, including the dealer. All found the alignment within spec.
I originally took it in due to the Left creep I was getting, with no luck.
Well I was changing the oil and noticed the inside tread on both front tires to be almost completely bald!!
I talked to Goodyear, and they said they couldn't warranty the tires, because it isn't the tires fault.
So had no choice but to get a new pair.
Bought from Discount though.
Well, I then took it to Network alignment, and they installed adj. cam bolts, and adjusted the camber out a little more, and said to keep an eye on them. (The tires)
I only had 13K on these tires BTW, and the rear tires looked good for maybe another 2500 miles!! 15000 out a set of tires is ridiculous, and I don't do burn outs at every light I stop at!
You might try Nitto's, the guy at Discount said he though they were a little better.
They are also cheaper.
I was selling my truck so I wanted the tires to match, so I went with Goodyears again.
Still had the Left hand creep though...
Old Aug 8, 2002 | 05:34 PM
robstaxi's Avatar
here are some pic's hope this works
Old Aug 8, 2002 | 06:33 PM
kidd2001's Avatar
Unhappy
I'm at 18,000 on mine. I probably need them now, but my walet is telling me 23-25. They don't stick like they used to.
