Touch Painting 101
Old Aug 4, 2002 | 12:05 AM
01Lightning's Avatar
Man, that is sweet...
Now, can anyone that wasn't there figure out from that picture how Tampa and Rampage were parked in relation to one another? I am too tired to try to figure it out...
Old Aug 4, 2002 | 03:11 AM
RTKILLA's Avatar
Its about time you told us your secrets!!
Now I'm going to be in the garage for the next couple days checking every last inch of my truck.
Old Aug 4, 2002 | 03:19 AM
Showya's Avatar
Hey guys, maybe Tampa might take his class ~ Touch Painting 101 on the road and set-up show in a town near you....
Have a good one folks, gotta get some sleep so I can go build another 2004 this morning, good to talk to you Rich BTW!
Showya
Old Aug 4, 2002 | 03:35 AM
AjRagno's Avatar
Originally posted by KYFordFreak
Everytime I tired to tpae something off and spray it, I got tape lines I couldn't sand out. I know I was doing something or several things wrong just do not know which ones. To thick of a coat, maybe?
A quality lacquer reducer/thinner, like "Parks" or "Sherwin-Williams" is essential. It will help the paint lay evenly.
Old Aug 4, 2002 | 04:46 AM
REDY2KL's Avatar
Great job man!
Old Aug 4, 2002 | 08:43 AM
GalaxyEng's Avatar
Nice job! Where did you get the airbrush kit?
Old Aug 4, 2002 | 09:08 AM
TampaSVT's Avatar
Posting Rights Suspended
From: I drive way too fast to worry about cholesterol.
Thanks, guys.
I bought mine from a hobby shop but Ebay has them for $14.00
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1754020935
Should work just fine for what we're using them for.
Rich
Old Aug 4, 2002 | 01:13 PM
krnlightning's Avatar
dang i wish u made a video haha well good job and thanks for the help
Old Aug 4, 2002 | 03:28 PM
loosebolt's Avatar
Thumbs up
Nice Job, Rich
For those thinking of doing this, be sure to use a good quality thinner, especially in this summer heat
Old Aug 4, 2002 | 03:29 PM
NorcalSVT's Avatar
If you say it's easy to do I may give it a try. I have about 3 rock chips in a cluster on the front of my hood. I was going to hire somebody, but you make it look so easy. Can you explain the sanding part. When you say wetsand, do you just soak the sandpaper in water & rub across the hood? I assume the dry sanding & the wetsanding for that matter uses very little pressure. You just want the paper to so the work?
Old Aug 4, 2002 | 07:55 PM
TampaSVT's Avatar
NorcalSVT:
You're right on the money.
Good thinner is a must for sure.
Be sure to tape around the affected area so you don't scratch when sanding.
Rich
Old Aug 4, 2002 | 11:01 PM
NorcalSVT's Avatar
Which thinner did you use? Should I just go to an autobody paint shop to locate the thinner?
I am going to do it next weekend.
Old Aug 5, 2002 | 08:58 PM
Chainsaw13's Avatar
From: Cuttin' Heads with Jack Butler at the CrossRoads!
Rich, got a question for you about mixing. What do you use to measure out the paint & thinner? I'm thinking an eye dropper would work well as there's not a lot of need to mix large amounts for one spot.
Well, make that two questions. I stopped by a paint supply store today and picked up a quart of PPG acrylic laquer thinner. Will that be ok to use?
Thanks,
Bob
Old Aug 6, 2002 | 08:02 AM
TampaSVT's Avatar
Thumbs up
Bob:
I usually do mine by filling the smaller bottles and pouring into the larger. Depending on the type of airbrush you use, a 1 to 1 mixture may work for you. Basically, if it clogs, thin it...
I like to mix up enough for a few times.
Rich
Old Jun 9, 2003 | 03:17 PM
Triton46's Avatar
I know this is a blast from the past, but do you happen to have the pictures on how you did this? I have a nice scrape on my door and I wanted to try and fix it using this method.
I have a few questions:
1)When you filled in the spot, did you use the brush or the air brush with the 1 to 2 part mixture?
2)Did you tape and then re-tape?
3)When you did the final pass 1 to 2 inches from the paint, did you still have the tape on the truck?
