Don't Tell (Red Lightning) Vinnie... ;)
SilverX - how'd you mount the tray?
I had a set of monster cable ends I was going to put on, but when I put them on the post they stuck up way in the air and I didn't like the way it looked, so I'm looking for others.
How deep is the hole in those fosgate ones?
Dan
Dan
The bottom of the stock tray needs a notch/slit on the sides, and on the front (part that faces engine) needs a notch also. Once you do that it's a bit of a tight squeeze. Basically your mounting the holder into the stock tray. There are monting holes on the billet holder to mount directly to the fender but there will be an ill effect from doing that, hummm wonder how I know.................
I might make it to whiskey cafe Sat, you can peep it out, or any other time. Your practically in my backyard, sort of.
Re: $5 optima battery holder
Originally posted by Coldie
I just went to Home Depot and bought some Epoxy Putty. mixed it, through it in a ziploc, fit it under the stock holder and around the central cell of the battery.
Poof! Custom battery holder.
Now this a custom battery holder!
