Interior light staying on...
Old Jul 16, 2002 | 07:43 PM
Coldie's Avatar
Question Interior light staying on...
My interior light is staying on. I would think it was the door switches, but the "door ajar" light on the dash is off.
Anyone have any ideas?
Coldie
Old Jul 16, 2002 | 07:44 PM
NozeBleedSpeed's Avatar
Check the thumbwheel for the dome light on your dash?
Old Jul 16, 2002 | 07:56 PM
Coldie's Avatar
yup.
Thumbwheel position doesn't matter. Of course I didn't check to see if the thumbwheel was working either....
Checking it.
Old Jul 16, 2002 | 08:03 PM
Coldie's Avatar
no problem...
The thumbwheel works. Is the "lights on" a seperate switch in the thumbwheel?
Coldie
Old Jul 16, 2002 | 08:11 PM
SVT_KY's Avatar
Rolled all the way to the top I believe ... kinda clicks ...
Old Jul 16, 2002 | 08:16 PM
Coldie's Avatar
Electrically...
I meant was it an actuall sperate switch. Could just the "interior lights on" switch die and leave the wheel functional?
Old Jul 16, 2002 | 08:37 PM
Coldie's Avatar
Wierd...
I pulled the fuse for the interior lights and they went off, but when I pulled the relay, they stayed on...
Coldie
Old Jul 16, 2002 | 08:44 PM
Nasty Wendy's Avatar
Did you check the little switch on the light itself?
Old Jul 16, 2002 | 08:51 PM
IBR8K4VETTS's Avatar
Angry
We have a lot of Ford trucks at work and about half of them have lights stuck on.....for $300.00 you can replace the computer that will fix it Mike
Old Jul 16, 2002 | 08:56 PM
SLP 97 CAMARO SS GUY's Avatar
i still say its a door switch. i would try a new door switch on drivers side first. if light is still on, that tells u the original switch was still good, so keep new one in, and pop out passenger side and put the original driver side one in there and see what happens. come to think of it, when u close the door on the truck, do the lights go out immediately, or do they stay on like 10-15 seconds then dim out? i mean how did they work b4 this problem. i have seen on the older town cars, the interior lights stay on for a while after closing the door, then they go out. we had a lady customer with an 89 town car complaining of the interior lights staying on constant, it turned out to be this little black box under the dashboard went bad. it controlled how long the lights would stay on after door was closed then make them go out. the box went bad and just left them on always. replaced little black box, and it was good to go. im not sure the Lightning works this way, thats why i was asking if they go out immediately when u shut door , or does it take a while. if they used to go out immediately as door was closed, my bet is bad door switch. hope i helped. Mike
Old Jul 16, 2002 | 09:00 PM
Coldie's Avatar
Immediatly I think...
But since the "door ajar" light is off, it means the door switches are closed, so it's not one of them.
Coldie
Old Jul 16, 2002 | 09:12 PM
r u sure the door ajar light is wired with the door switches that operate the interior light? some cars have 2 door switches, one does the light, in door jam and another switch does door ajar. to be sure open one door, and look for door ajar light on dash, keep door open and push door switch in with your finger and see if door ajar light on dash goes out, if it does, then u r right. but i would try that on both doors just to be sure u rule out door switch. cant be possible both switches went bad. give that a try. Mike
Old Jul 17, 2002 | 11:27 AM
Coldie's Avatar
any other ideas?
Coldie
Old Jul 17, 2002 | 12:26 PM
Coldie's Avatar
My bad...
I thought I had to be different. After talking to my Service guy, he confirmed that there are two switches in the door, one for the "door ajar" light and one for the interiors.
Coldie
Old Jul 17, 2002 | 12:39 PM
LIGHTNINROD's Avatar
Are the interior lights the only ones that stay on? What about the third brake/exterior lights or the hood-open light?
There must be a short-to-ground somewhere?
Dan
