AFM PowerPipe
Old Jul 15, 2002 | 04:57 PM
Mondo1's Avatar
Ther most definately is a power gain with a pipe replacing the corragated rubber inlet hose. My 98 Cobra had a pro-M 8omm mass air on it with the factory rubber inlet. When Joe at UPR replaced it with his 4 inch metal inlet we picked up another 6 H.P. I would guess the gains on a supercharged engine are AT LEAST that. Ron Anderson sells the ***** out his powerpipes that replace the plastic Vortech pipes....and they're already smooth!!
Old Jul 15, 2002 | 05:29 PM
Black 2000's Avatar
Right....
But there's the Dyno graph showing, what a 10 HP gain wich is the same gain that are noted with a 12" filter and MAF upgrade.
So, maybe someone else can chime in here with some actual track and Dyno experience with it.
Just my .02
Old Jul 15, 2002 | 05:39 PM
Odin's Wrath's Avatar
Sal,
I'm on top of it. Thanks for the tip.
Fast Gator,
11.5 inches minimum from dead center of the throttle body to dead center of the MAF, end to end. If you need longer, theres another inch at least to play with in the connectors.
Black 2000,
Thanks! I'll have to get some of those.
As far as power goes, I think this kit will show more improvement on modded trucks. Restrictions are felt more strongly as you make more boost. Therefore you should benefit more as you remove flow restrictions. Someone posted a while back that they added the pipe to their jdm induction kit and made an extra pound of boost. I can't remember who. Hopefully they will speak up.
I have a definite improvement over the kit I had before, and it only cost me a little more for the AFM kit with a Power Pipe, than it would have cost for one of the kits we have had available to us in the past. I've been thinking about going to the 92mm GMS MAF in the future. This kit will handle the extra air with room to spare. It will even work with the 100mm that is supposed to be coming up. That's too much for my needs; but, somebody will be using it.
Just my .02,
Roger
Old Jul 15, 2002 | 05:42 PM
Re: Right....
Just my .02
I'll be going to the dyno soon for some info for a chip reburn. I'll run the corrogated as well to see if there is a difference.
Old Jul 15, 2002 | 05:46 PM
Black 2000's Avatar
Thankyou...
I've been looking into the Power Pipe ever since I saw it advertised in a Mustang mag. Keep us posted, please.
Later...
Bruce
Old Jul 15, 2002 | 06:56 PM
Marc Arnold's Avatar
Re: Right....
Just my .02
Was testing a few parts on the AFM dyno last week on my '01 and Rick and I saw 7rwhp with the P.P. At the time, all we had on the truck was a Bassani cat-back.
Last time I turned the board onto the AFM P.P.'s for the L I got blasted by the admin, so these are just my personal experiences on my truck.
Old Jul 15, 2002 | 07:08 PM
Mondo1's Avatar
Re: Re: Right....
Plus, we do not know what kind of conditions there were at the time of the dyno ie: temp, humidity, sea level...plus dyno's (especially dynojet 150's) vary quite a bit from each other. 7 H.P. sounds right with this mod , as I have seen this myself.
Old Jul 15, 2002 | 07:47 PM
Black 2000's Avatar
Re: Re: Re: Right....
Now what was the truck dynoed at with just the P.P. and not the exhaust. I believe we are trying to decide if there is an actual gain with the Power Pipe alone and no other mods.
Thanks guys...
Bruce
Old Jul 15, 2002 | 08:39 PM
Re: Re: Re: Re: Right....
Thanks guys...
Bruce
Bruce, if you mean my post, those 7 ponies were due to P.P. alone. Bassani was on the truck for both tests.
Old Jul 15, 2002 | 08:42 PM
Black 2000's Avatar
Ok...
Old Jul 15, 2002 | 08:54 PM
Fast Gator's Avatar
Originally posted by Odin's Wrath
Fast Gator,
Thanks buddy, I owe you a beer
Old Jul 15, 2002 | 09:31 PM
BEER? Did someone say BEER?
Any time!
Old Jul 16, 2002 | 05:47 AM
Fast Gator's Avatar
