Oil and filter question
Old Jul 10, 2002 | 12:16 AM
L8 APEX's Avatar
I like the Mobil1 M210 filter. It is costly but I like the quality. I have replaced a few Motorcrap 820S's(cheap shot) on customer trucks due to seem leaks etc.. There used to be a real good link to a filter study on which ones prevented backflow, had metal, rubber, or cardboard gaskets and media types inside...
junehhan's Avatar
Post
Last I heard, SVT is now recommending that we top off the line with 6 quarts, so who knows..........
I just did my second oil change done yesterday at 3500 miles, and I went ahead and used 6 quarts of Mobil Drive Clean Blend along with a Mobil 1 filter. I would say as long as you are using a Mobil 1, K&N, or Motorcraft filter, you are doing just fine. Just don't use a Fram, or cheap Wix, but then again you guys probably already know that from owning such fine trucks!
Old Jul 10, 2002 | 12:41 AM
BADBOLT2's Avatar
No matter which oil you use stay with the Motorcraft 820s or risk the "can of marles" sound at cold startup.[been there done that!]
The "S" stands for the silicone anti-siphon valve built into the filter.I'm not a know it all by any means.I called SVT!
hope this helps!
Old Jul 10, 2002 | 10:24 AM
Bomeyer15's Avatar
Thumbs up
6 qts Mobil 1 5W-30 and Motorcraft FL-820S
Old Jul 10, 2002 | 10:47 AM
slapshot's Avatar
I have 22.5K miles on my 99 now. I have been using 5W-30 oil and the 820S filter. I am thinking about going to Mobil 1 5W-30 synthetic on the next oil change. As far as I know, the truck has had regular oil in it and has never had synthetic. Has anyone had problems after changing to synthietic?? I have heard of people having oil leaks and burning problems after making the change.
