6lb Pulley Drivability Issues
Old Jul 5, 2002 | 07:19 PM
SVT-Guy's Avatar
Question 6lb Pulley Drivability Issues
I've had my L for a while now, and just like everyone else on this board... it's time for the modding. I was thinking of going straight to the big dogs in terms of pulley size. The 6lb'er. However, would this cause any daily drivability problems. I drive the L about 50 miles a day. I have seen other discussions about the 4lb'er being all right, but I wanted some first hand info from any of you all out there that are running the 6lb pulley. TIA
The 6lb pulley would be in addition to a 3/4 drop, chip and filter. Thanks a lot.
Old Jul 5, 2002 | 07:30 PM
ICULOKN's Avatar
NO biggy to use a 6lber anymore. Big brother 8lber is out now....
Old Jul 5, 2002 | 07:52 PM
SVT-Guy's Avatar
So, basically, it wont put a lot of premature wear on the engine from the increased boost?! Also, is there anything else that I should do/mod to insure that everything runs properly?
Old Jul 5, 2002 | 08:05 PM
LIGHTNINROD's Avatar
Thumbs up
It really doesn't matter that much if you run a pulley daily unless you can't keep from going to WOT/boost. Do get a properly tuned chip with the pulley.
I drive about 75 miles daily with a 5 lber with no issues and I'm at 30,800 miles now.
Dan
Old Jul 6, 2002 | 01:24 AM
junehhan's Avatar
Question
Out of curiosity, for you guys who are running lots of boost with a pulley, and daily drive your vehicle constantly, what kind of spark plugs are you running, and what kind of useful life could you expect from them?
Old Jul 6, 2002 | 01:50 AM
SVT-Guy's Avatar
ahh, there's something I forgot... what plugs should I run with the 6lb setup... good question junehhan
Old Jul 6, 2002 | 02:15 AM
wrightlightning's Avatar
Lightbulb
SVT-Guy
I run a 4# lower with the LFP upper. Mine is a daily driver with several thousand miles on this combo. I agree with LIGHTNINROD, you will be fine as long as you do not stay WOT/under boost constantly. Most important thing is to have your chip programmed with the pulley in mind. I run the NGK TR6s, BTW. Hope this helps.
Old Jul 6, 2002 | 05:28 AM
blown318's Avatar
Thumbs up
5lber here with 18000 miles daily driven......No problems yet.
Old Jul 6, 2002 | 05:49 AM
blown318's Avatar
whos got the 8lber out???? damn, thats alot of boost!!
Old Jul 6, 2002 | 09:31 AM
JeffsLightning's Avatar
How about a 7 lber?
Option A : 2+ psi Crank Pulley
32+ additional horsepower
7.90" diameter crank pulley
Option B : 4+ psi Crank Pulley
44+ additional horsepower
8.45" diameter crank pulley
Option C : 7+ psi Crank Pulley
54+ additional horsepower
8.95" diameter crank pulley
Old Jul 6, 2002 | 10:23 AM
Fast Gator's Avatar
Iam holding out for the 10lber
Denso's are the plug of choice, Yeah I know, $$$
Old Jul 6, 2002 | 10:31 AM
Sap-One's Avatar
With these aftermarket pulleys does it make it possible to smoke the tires from a dead stop or a roll? Im looking to do this because I miss slamming second gear in my mustang. Thanks,Mike
Old Jul 6, 2002 | 11:13 AM
blown318's Avatar
Haha in the cold on my 20s I could smoke the tires into third gear no problem..... scare the chit outta my passengers!! LOL
Old Jul 6, 2002 | 11:16 AM
Thumbs up
As my drill instructor use to say, "Smoke 'em if ya got 'em."
I'm running with NGK BR7EFs but they're too 'cold' for low rpms street driving so when I get the gumption to do it again , I'll install the Denso IT24s that are waiting on my workbench.
Dan
Old Jul 6, 2002 | 11:20 AM
soap's Avatar
Do you even have a Lightning..........bone stock with 5mi on the ticker I could blaze my tires for blocks without even trying.
And besides what does smoking your tires have to do with slamming second gear??
--Joe
