Can I nail second gear?
Old Jun 26, 2002 | 10:21 PM
frgetit's Avatar
Hey. I love my L and don't miss anything about my cobra except the manual tranny(well, the convertible a little). Anyway, today I laid in the throttle a little to get moving, went through first gear and then got off it....during the shift from 1 to 2 I changed lanes and gave it throttle again before it shifted and when it went into 2nd.....eeeeeeeeeeee! I dug the shi* out of it! It made me remember how much I miss dropping the clutch and setting my cobra sideways in 2nd. Of course, it was a 99 with the IRS and a few of those and the half-shaft would break and she would be in service for a week. It was sweet while it lasted though. Anyway....is there a way to bust 'em loose with our Ls other than manually shifting from 1 to 2 and nailing it during the shift or doing it by accident like I did? How tough are these trannys. Just FYI, I dont enjoy beating my sled, she has 3K on her and I am still afraid to stick it because shes still gettin broke in. Anyway, just miss hearing the tires break after the shift....thanx guys.
Old Jun 26, 2002 | 10:30 PM
Silver_2000's Avatar
Get a line mod valve or the PSP / FT Modulator kit
That will give you the 2nd gear action you are looking for
Doug
Old Jun 26, 2002 | 11:21 PM
Fowl's Avatar
It is possible that a good chip will do that too.
Old Jun 26, 2002 | 11:24 PM
E3LilE8Harv29's Avatar
YUP! Mine sounds like a cam and gear drive! hehehehe!
dealerjim's Avatar
100% correct. After I had the line mod installed I thought it was a whole new truck. It would also help if you had a chip programmed to take out the 1-2 shift torque reduction. Man what a difference!!!
Old Jun 26, 2002 | 11:30 PM
Twisted99's Avatar
My problem is I can't stopped smokin` it through 2nd.
But I would rather have my problem than your's.
Old Jun 27, 2002 | 12:49 AM
DaveRed99's Avatar
Thumbs up lol!!!
Hell ya ! me to........ well said...
Old Jun 27, 2002 | 10:38 PM
frgetit's Avatar
So all I need is the line valve mod? I want a chip like I want Elizabeth Hurley spread eagle naked on my mattress, but I am too afraid of 86'ing my warranty. Is there anything else I need to go with it? Where do I get a good one?(not trying to start a tuner war either.......kind of sad that I even have to mention that eh..) Is it hard to install? Thanx for all the help you guys rock!
Old Jun 28, 2002 | 06:06 AM
DR.D's Avatar
Yea
Having the great fortune to have Elizabeth Hurley spread-eagle on any mattress is NOT going to void your warrantee. They might want to extend it if you can hook them up.
Go to PSP and read about line mod and FT valve body. It will help you decide. Remember Line mod is just fine, valve body just may be better for the trans in the long haul. You decide. I haven't heard of a failure attributed to a line mod as of yet, tho' I plan on the valve body. I do remember reading that letting off on WOT at the wrong time can obviously cause it to shift extremely hard and can be detrimental.
www.powersurgeperformance.net
Old Jun 28, 2002 | 10:30 AM
VINNIE's Avatar
Frgetit
Here is some pictures of a JDM line valve mod
Tanny with pan off
Valve Body to remove
Old Jun 28, 2002 | 10:33 AM
VINNIE's Avatar
Installing Larger valve
Put all back together w/4x4 pan
Old Jun 28, 2002 | 01:20 PM
FooFur's Avatar
how hard is it to install a linemod valve ? should it be done by a pro ?
Old Jun 28, 2002 | 04:08 PM
DR.D's Avatar
If you can turn a wrench you can do either line mod or FT valve body.
Old Jun 29, 2002 | 05:29 AM
EXCITED's Avatar
taking out torque reduction is the worst thing you can do to your transmission=early destruction, leave torque reduction ON!(
Old Jun 29, 2002 | 05:32 AM
EXCITED's Avatar
get gregg evans/factory techs valve body instead.. your tranny will thank you in the long run
