Nitrous and 5LB pulley
Old Jun 24, 2002 | 04:38 PM
blown318's Avatar
Question Nitrous and 5LB pulley
Is anyone running Nitrous and a 5lb pulley?? Would u guys recommend it?? if so how big of shot are u going with??? it wouldn't be sprayed all the time just for emergencies Also what type of plugs would be recommended to run?? I already have denso IT 22s. I was wondering if those were good enough?? any help is greatly appreciated..
Old Jun 24, 2002 | 04:45 PM
J15BIG's Avatar
I wouldnt do it unless you have a built motor. with 5lbs and juice your asking for trouble unless you have a built motor. If your goin to run a pulley a nitrous dont go above 4lbs and 100 shot. 100 shot is pushing it a little imo but i would consider 100 the absolute max!
Old Jun 24, 2002 | 04:47 PM
blown318's Avatar
damn, I wanted to run just a 50 shot at the track for a couple of passes... nothing bigger than that... just to cool things off a little bit.... and in case i find a little action on the street
Old Jun 24, 2002 | 04:58 PM
J15BIG's Avatar
you will probably be ok then with just a 50 shot and a 5 lber
Old Jun 24, 2002 | 05:02 PM
blown318's Avatar
Anyone else?? Anyone??? Sal, u run a lot of nitrous... what do you think??? thanx j15
Old Jun 24, 2002 | 05:07 PM
StruckBy99's Avatar
Oh no.........will it ever stop
Old Jun 24, 2002 | 05:10 PM
blown318's Avatar
Hey leave me alone....LOL or im never gonna let u borrow my slicks again LOL. Did u get your convertor problem taken care of?? cause I might go to track friday and I was gonna see if u wanted to go up there also... let me know..
Old Jun 24, 2002 | 05:15 PM
DaveRed99's Avatar
i would go .....
2 pounder and a 75 shot... youll be preety happy just get a chip from Sal.. or who ever and you'll be moveing ! or you can do a 4 pounder and a 50 shot... but that is kinda push'n it lol
Old Jun 24, 2002 | 05:17 PM
LightningTuner's Avatar
These are our suggestions for nitrous with stock motors:
Stock boost up to +2 psi- 100 shot
+2psi to +4 psi - 75 shot
+4 psi to +6 psi - 50 shot
Over +6 psi, not recommended.
You can get away with more on a 99-00 motor, but going over these guidelines on an 01-02, is not suggested.
I'm sure there are those who have exceeded what I suggest with no problems, but I made those limitation guidelines based on the majority of failures.
Old Jun 24, 2002 | 08:23 PM
blown318's Avatar
TTT
Old Jun 24, 2002 | 09:00 PM
LightningTruck's Avatar
Youse guys are Nucking Futs!
Supercharger + Nitrous = KABOOM!!!!
Now I know where those pictures of melted spark plug electrodes come from.
NHRA rules ban the use of a supercharger with nitrous.
Old Jun 24, 2002 | 10:29 PM
SouthernStar's Avatar
Cool
I have been hanging around this site for about 6 months now and it is becoming increasingly clear that most of the folks that warn against using nitrous know very litle about its use. Find a tuner that has experience and listen to them! Not the other people (vultures) who sit on the fence and wait for motors to go kaboom. Sal seems to be the best one out there for nitrous knowledge. I have a 99 L with a 6# lower and run a 75 shot, but only in the 1/8 mile. The real question is cylinder pressure and if you happen to have a "weak" rod from the factory. My truck has 43K and seems to still be running strong. However, it is true whenever you push the envelope as far as mods are concerned, without careful attention to detail and a little luck, you can expect the unexpected. Run the 50 shot and you should be fine.
Old Jun 25, 2002 | 01:02 AM
CHIKIN1's Avatar
Hey 318:
I've got a TRUE 2# upper and 3# Lower!!!
I run a 75 shot on my truck about 3-4 times a month with NO problems to speak of yet!!!
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
424HP/528ft.lbs @ Normal Temp. w/o N2O
LFP 2600 P.I. Stall Converter
JL Logocaps w/Keychain
JL 3# Lower Pulley
Sean Hyland 2# Upper Pulley
JDM Cold Air
JDM Boost Bypass
JDM/Accufab Throttle Body
JDM Longtubes w/ Silver-Bullet cat-back
JDM Cobra R pump
JDM Eletric Fan
JDM 2” Drop Shackles
PSP 4-Way Autologic Chip ( Tow, Street,Track, N20 )
PSP FactoryTech Valvebody
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
Nitrous Express 50-150 Kit ( Can’t decide which jets to use )
NGK / TR6’s ( .040gap )
Hoosier DOT’s 28 x 10 x 16
NEXT:
Built Shortblock w/Ported Heads
Monster Box Tranny
JDM 205 blower and 100mm MAF
AND DEFINITELY SOME BIGGER SLICKS
Old Jun 25, 2002 | 07:35 AM
Blown93's Avatar
I say Kaboommmmmmm it wont last long with it, I go along with Sal......
Blown 93 lightning
1.83
13.2
103.00
True Blue
Stock
1.98
13.44
102
Old Jun 25, 2002 | 10:59 AM
JBsvt's Avatar
90 percent of these people are stupid . I have a 5lb pulley and shoot 90hp of juice, truck runs fine. If you dont use nitrous dont comment, you look dumb if you do..................
