Front tires rubbing.......
Old Jun 23, 2002 | 11:21 PM
blowntruck's Avatar
Unhappy Front tires rubbing.......
Lowered my L 2/3. Did the endlink change. Have Belltech shocks on. Truck handles like a dream around curves. Now the problem is when I go to my usual twistie road to try it out my front tires rub inside the top fenderwell like a ****. Yes this road has alot of quick drops or drastic hills so it only does it here. Still it is irratating.
So my question is, what shocks should I get? Im guessing I need stiffer shock. I also want ones that will ride nice on the highway since I do alot of driving. These are the ones I have in mind.
*Edlebrock IAS
*Doetsch
*Doetsch Adjustable's
*Bilstien
*Or maybe, only 1 pair of QA1's
What do you'all think??
Old Jun 24, 2002 | 11:05 AM
blowntruck's Avatar
Talking
TTT
Old Jun 24, 2002 | 12:15 PM
LIGHTNINROD's Avatar
I put the Edelbrock IASs on my 97 xlt F150. I would not use them again.
I think Spike Engineering is 'high' on the QA1s.
Dan
Old Jun 24, 2002 | 02:26 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
You tested the trucks new handling characterisitcs on a road with bumps and quick drop offs?
find another test road or slow down.
QA1's
Old Jun 24, 2002 | 03:16 PM
Silver-Bolt's Avatar
Sounds like too soft of springs to me. What is the spring rate?
Old Jun 24, 2002 | 03:19 PM
Spike Engineering's Avatar
Shocks won't help. Different springs and/or tires&wheels will help.
Spike
Old Jun 24, 2002 | 04:28 PM
blowntruck's Avatar
QA1's
You right. On the highyway it handles great. Even though it still rubs when at high speeds on the highway I hit a quick bump or dropoff.
Originally posted by Spike EngineeringShocks won't help. Different springs and/or tires&wheels will help.
Spike
Okay, im not ready to change tires and wheels yet. So by different springs im assuming you mean stiffer, right? What other kind of springs can I get to correct this problem and still keep my front-end drop?
Thanks everyone.
Old Jun 24, 2002 | 04:51 PM
lemme guess, Eibachs?
A set of specific rate springs should alleviate some of your concerns.
I'm running a set of 1000/lb coils from Ruslow and have no ill effects. Ok, maybe a little loss of ride quality and still have a drop.
It boils down to better handling and bit rougher ride vs. handling like ****e and riding like you're on a cushion. I'll take the former.
