cavitation?
Old Jun 13, 2002 | 02:30 PM
clonetek's Avatar
cavitation?
right click & "save as" to your desktop.
http://home.jam.rr.com/clonetek/cavitation.mpg
is this sound anything to worry about? if not i'm gonna leave it alone.. i almost wish it would do it louder so that it'd sound like the orange car.. LOL LOL
Old Jun 13, 2002 | 02:42 PM
rickgig's Avatar
Hmmm... never heard that before... no idea...
Old Jun 13, 2002 | 03:08 PM
ICULOKN's Avatar
Thats a wild noise. Soudns liek a rotor pack taking a crap. Thats alot of grinding sound....
Old Jun 13, 2002 | 03:16 PM
clonetek's Avatar
its not really a grinding sound.. it's more of a whistling sound..
maybe the camera didn't do a good job of transfering the sound?
if it was a lot louder, it would sound like a vortech blower.
thats the sound it makes.
Old Jun 13, 2002 | 03:20 PM
ICULOKN's Avatar
Does it do it more at idle? and in gear? What pulley do you have?
When I had my 6lber it would do it, but its normal....
Old Jun 13, 2002 | 03:23 PM
clonetek's Avatar
mostly at idle.. and i have a 2lb lower pulley.
it went away when i pushed the throttle linkage..
Old Jun 13, 2002 | 03:31 PM
beefcake2002L's Avatar
Registered User
Does is sound like a bunc of marbles being stirred around?
It's hard to tell from the vid...
Old Jun 13, 2002 | 03:55 PM
ICULOKN's Avatar
Thats the normal sound then I think. Mine does it, JL's 99 & 01 did it, I heard it on his when I was at Cecil, Erics did it. Its just blower noise from idle...
Old Jun 13, 2002 | 04:02 PM
93Cobra's Avatar
Definitely a normal sound - mine has made that noise from day one.
Old Jun 13, 2002 | 04:11 PM
AggieSVT's Avatar
That sounds to me like a loose belt, more than cavitation. It is really hard to tell from the video, but if you had some belt dressing(yes, I hate that sticky stuff too, but it will at least help you diagnose this problem), spray a little bit on the inside of the belt when it is running. If your noise immediately goes away for even a second, its belt noise.
Just to ease your mind that is an easy way to rule out the belt making the noise. When I put my 2# upper pulley on, it did the same sort of thing until I got another belt.
Old Jun 13, 2002 | 05:20 PM
PT's02L's Avatar
Sounds like it might be an idler pully bearing.
Try removing the blower belt & crank it up (don't rev it). This will tell you which belt is producing the noise. Then, using a stethascope (sp?) or long rod (several socket wrench extensions will do), listen to everything that rotates on the belt making the noise. Note: place your listening device on non-moving parts!
I had a Mustang 4.6 with Ford's S/C that had an idler pully noise simular to your noise.
Old Jun 14, 2002 | 02:57 AM
clonetek's Avatar
i'll try to tinker around some this weekend..
Old Jun 14, 2002 | 05:45 PM
easterisland's Avatar
Mine sounded like that with the upper and lower pullies. In park it didn't make the noise as loud, but in drive when the rpm's came down a little the noise was pretty loud. I've been living with it for about 8-9 months now.
