Need help setting TPS
Old Jun 9, 2002 | 05:44 PM
415cid Goose's Avatar
I can't seem to get it to adjust. I loosened the screws but it won't turn up or down. Please help. I used Clonetek's thread to help me out, but could not get it to adjust.
Old Jun 9, 2002 | 06:07 PM
Ak.Silver2K's Avatar
Goose,
It doesn't move much at all, and mostly clockwise or counter-clockwise. Just set mine last nite. Couldn't get a good voltage reading, so I moved it untill I liked results.
Mark
Old Jun 9, 2002 | 06:08 PM
speeder's Avatar
TPS Adjustment
You might need to use a file to make the screw holes a little bigger, then you should be able to adjust it.
Larry.
Old Jun 9, 2002 | 08:32 PM
The lowest reading I got by moving the TPS was 1.01. I then turned the screw on the back of the tb and got a reading of .98, so I should be ok right?
Old Jun 9, 2002 | 10:42 PM
Yes, reading is supposed to be less than 1 volt from what Babolt told me. But I don't think the TB screw had anything to do with it.
Mark
Old Jun 10, 2002 | 08:20 AM
LIGHTNINROD's Avatar
Mark:
Mark
Yes, turning the t/b screw will move the throttle shaft and the shaft 'moves' the potentiometer inside the TPS. I believe the 'book' tells us to adjust the screw first for a normal idle speed and then adjust the TPS to get .999v or less. Moveing(radially) the TPS will not affect the screw adjustment(idle rpm) though.
Dan
