Fog light bypass
Fog light bypass
New to the board, just picked up my 02 HD. Figured you guys have the most tech knowledge since the HD site is so new. Is there a way to run the fogs without the headlights being on? There was a simple fix on the cobras but this is a much different animal. Thanks.
Here ya go... check out this link. This is how many of us have done it...
http://www.svtlightnings.com/svt/foglamps/foglamps.htm
I just did mine this weekend while I had the switch out for my new gauges. Did mine a little different, I found the wire that was hot when the switch is in the parking light selection. Then looked for the hot wire when the fog lamps were on. After doing this I put a jumper wire between the 2 wires. This makes the fog lights come on anytime the parking lights are turned on. I do not use it but for the people using the autolamps the way I did it the fogs will come on with the autolamp. Hope this helps, also if anyone is interested I will take some pics and get the colors of the wires that are to be used.
Originally posted by tommylightning
. . . Hope this helps, also if anyone is interested I will take some pics and get the colors of the wires that are to be used.
Thanks in advance,
TLS
[/IMG]
