oil in throttle body
Old Jun 4, 2002 | 09:03 PM
gp's Avatar
gp
ive seen these air compressor filter set ups and how they keep the oil out of the throttle body.i also read way back that if you only put 5 and 1/2 guarts of oil in the motor you wouldnt have this problem.so,whats the best way to solve this problem?
Old Jun 4, 2002 | 09:34 PM
PT's02L's Avatar
Put some form of oil separator in the PCV line (passenger side valve cover - to - S/C intake). An air compressor filter is good. Some form of bottle with a line in and a line out will also work.
Some owners plug the opening(s) in the intake system and put breathers on the valve covers, but I am not going to do it. A) it's not legal in my state, and b) it might change the air/fuel ratio a little.
I read a thread (forgot author, sorry) that the oil comes through the PCV line for two reasons; 1) the PCV valve is not shrouded and oil gets thrown at it by the cam and, 2) backing off from high boost puts an enormous amount of vacuum between the T/B and the S/C which sucks the oil into the intake. I doubt running less oil will change this. A separator or breather seem to be the only fixes.
I'm sure you've seen this by now:
https://www.f150online.com/forums/sh...threadid=79626
Old Jun 4, 2002 | 10:27 PM
Jay Lincoln's Avatar
You can check out this link also. This explains how it is done.
Jeff'sLightning did a more compact install than I did. I was using parts that I already had on hand.
[https://www.f150online.com/galleries...w.cfm?num=1498]
