I went to the track
Old May 27, 2002 | 11:01 PM
REDY2KL's Avatar
Unhappy I went to the track
I saw two L (silver and silver) but the one ran 15.xxx and the other ran 14.xxx whats up with that. We are at about 5,000 feet altitude.
Old May 27, 2002 | 11:29 PM
FastAsL's Avatar
14 flat at 5,000', thats a pretty good run!!
Old May 28, 2002 | 12:42 AM
REDY2KL's Avatar
But what about the other L that ran 15.xxx ????
Old May 29, 2002 | 12:51 PM
BLOWN HARD's Avatar
Probably traction... it can be a pain to get these machines to hook some times! -Just my $.02
Old May 29, 2002 | 12:55 PM
DB's Avatar
DB
Altitude will cut your times significantly (as well as heat).
Most of the folks running the really low numbers are doing so within a few hundred feet of sea level.
Old May 29, 2002 | 01:14 PM
jmimac351's Avatar
Pay attention to the MPH when you are looking for how well a vehicle is running. MPH is a better indicator of how much hp a vehicle is making. You may see a fast vehicle run a slow et because of traction problems but you will NEVER see a slow vehicle run a big mph - traction problems or not.
Old May 29, 2002 | 04:50 PM
BLOWN HARD's Avatar
Very true Jim... very true
Old May 29, 2002 | 08:53 PM
Jay Lincoln's Avatar
If you raced at Bandimere, the altitude correction factor for ET is .9508 to equate to sea level. The MPH correction is 1.0563. It's pretty accurate.
My corrected ET from LACR was 13.11 to sea level. The track is at 2700' above. My acutal ET at Carlsbad was 13.11. Carlsbad is about 60' above sea level.
