Drive shaft loop location
Old May 11, 2002 | 03:34 PM
Silver-Bolt's Avatar
What is the rule (NHRA) on the drive shaft loop location? How far back from the fron u-joint?
Old May 11, 2002 | 03:39 PM
soap's Avatar
Pretty sure it is 6" back from the U-joint.
--Joe
Old May 11, 2002 | 05:07 PM
Chikenears's Avatar
Joe is wrong, it 14 feet. J/K, he's right
Old May 11, 2002 | 07:04 PM
Lightning Boy's Avatar
That would be correct, 6" back from the U joint. The Lightning's frame comes pre-drilled with many sets of holes you to use.
Old May 11, 2002 | 08:29 PM
clonetek's Avatar
i got one from johnny lightning..
ah.. heres a better one:
Old May 11, 2002 | 09:19 PM
Thanks guys. Glad I askes, I was thinking it was 12".
Old May 11, 2002 | 09:40 PM
LightningTruck's Avatar
Hey Brooks
What muffler is that under your truck? Did you get a power gain from it and did you have to hack up the stock muffler?
Old May 11, 2002 | 09:43 PM
clonetek's Avatar
its a stainless steel magnaflow.. can't remember what number it is.. maybe someone can chime in..
no real power gain, but the truck sounds much better.. yes i had the stock muffler cut off... tossed it in the trash.
Old May 11, 2002 | 09:50 PM
14468 is the SS shorty and 14568 is the SS long. Short one sounds better. I have the 12468 same thing just plated instead of stainless. Cutting and a little tube bending is required. $150-$200 installed.
Old May 11, 2002 | 10:06 PM
Don's Bolt's Avatar
Here is a pic of where my loop is mounted
Old May 11, 2002 | 10:15 PM
Don
How hard was it to get to the bolts from inside the cab?
Very nice exhau$t!
