Springs
Old May 9, 2002 | 10:38 AM
CHIKIN1's Avatar
Question Springs
Anybody know of some front springs that will lower my truck about 1" and help straight line traction ( as most lowering springs kill straight line traction )???
Also does anybody know if putting on my 2" drop shackles will change anything with my Truck-Tracs???
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
424HP/528ft.lbs @ Normal Temp. w/o N2O
JL Logocaps w/Keychain
JL 3# Lower Pulley
Sean Hyland 2# Upper Pulley
JDM Cold Air
JDM Boost Bypass
JDM/Accufab Throttle Body
JDM Longtubes w/ Silver-Bullet cat-back
JDM Cobra R pump
JDM Eletric Fan
JDM 2” Drop Shackles
PSP 4-Way Autologic Chip ( Tow, Street,Track, N20 )
PSP FactoryTech Valvebody
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
Nitrous Express 50-150 Kit ( Can’t decide which jets to use )
NGK / TR6’s ( .040gap )
Hoosier DOT’s 28 x 10 x 16
Old May 9, 2002 | 10:47 AM
NeedFourSpeed's Avatar
A couple of things you can do to the front end to help traction are:
1. remove or disconnect the sway bar.
2. Relocate the battery to the back of the truck.
3. Use some "softer" shocks (we used to call them 90/10 drag shocks; it has to do with the way they are valved). I think you can get some adjustable shocks for the tuners. Basically they allow the front end to pop up quicker which give you better weight transfer.
Old May 9, 2002 | 12:20 PM
JBLsilver01's Avatar
not sure about improving traction, but i put in some Belltech 1" springs, lowered it 1 inch exactly. Traction is about the same as before though, with just the 2" shackles.
Old May 9, 2002 | 12:40 PM
LIGHTNINROD's Avatar
James:
I have the 2" shackles and the Truck-Traks. They work fine togeather.
Dan
Old May 12, 2002 | 01:35 AM
WrongdayJ's Avatar
You want to drop the rear.
The more favorable pinion angle will help your drag launch.
Relocating the battery helps.
You won't have any problems with the truck traks.
Several folks I know run this combo very successfully, and can STRAIGHT UP BOOGEY out of the hole even on F1's. I had a friend of mine (who has the factory tech valve body) with the exact same set-up you mentioned launch side by side with an eagle talon AWD running 20+ lbs of boost. In case you've never run an AWD turbo talon before. . .this is not an easy task for any vehicle. . .let alone a full size truck. I should have exact 60 ft times after I talk to him this week. Sub 1.90's are not out of the question though by any means.
GO FOR IT!!!
