Tire Rotation?
Old May 8, 2002 | 04:49 PM
mecca's Avatar
Tire Rotation?
I was wondering how often you guys rotate your tires? Im young, and dont wanna save myself as much money as I can. Also, I received 2 Manual's on my truck. One is the SVT Manual, and the other is just the Regular F-150 Manual. They have 2 different diagrams for rotating. Do you guys rotate the fronts to back and backs to front, or do you rotate the fronts to the back, and the backs crossed over to the front?
Thanks - Mike
Old May 8, 2002 | 04:51 PM
qball2439's Avatar
you can't really cross rotate these because they are directional..I rotated them at 4500 miles
Old May 8, 2002 | 04:54 PM
mecca's Avatar
Would rotating my tires every 2,000 miles be stupid?
Old May 8, 2002 | 04:57 PM
qball2439's Avatar
i would say, just watch your tire pressure and make sure it's aligned properly and rotate them every 4-5K for best tread life...
that's my .02
Old May 8, 2002 | 05:01 PM
mecca's Avatar
What tire pressure do you guys run? Different from whats in the manual?
Old May 8, 2002 | 06:28 PM
soap's Avatar
32psi at all 4 corners for street driving.
--Joe
Old May 8, 2002 | 08:01 PM
mecca's Avatar
32psi, does this go for F1's? Or only ET Street's?
Old May 8, 2002 | 08:39 PM
Boostin01L's Avatar
Hey mecca This is off topic but I wanted to know how you like your subs those are the ones I was thinking about buying? Would you buy the same ones over?
Old May 8, 2002 | 09:22 PM
mecca's Avatar
Hey Boostin,
These 2 10" Pioneer's are perfect for the styles of music I listen to. Im mainly a rock/punk fan. On ocassion I listen to some rap. But the 2 10"s and custom box sound great. Id recommend them. Im going to be purchasing a set of Crystal 6.5" components soon powered by a JBL 180.2 amp. This should make my system sound 100x's better, and I will be even more happy with my sub's. If your gonna get the 2 10"s, id recommend replacing the stock speakers. Or in any case, replace the stock speakers, because they sound like s#!t!. Just my .02!
- Mike
Old May 8, 2002 | 09:23 PM
soap's Avatar
F-1's.........I did say for street driving
I use 16 psi cold in my ET Streets.
--Joe
Old May 8, 2002 | 09:29 PM
mecca's Avatar
Lol. Sorry. Im uhm, quite a bit slow. =P
Thanks though.
- Mike
Old May 8, 2002 | 10:12 PM
SVT_KY's Avatar
Ummmmm ...
Buy them two at a time ... Burn the backs rotate the fronts
back, then new on the front ...
OR ... You can be like Crazyone and have F1 SLICKS on the back !!!!
Rotation is all on one side .... cause the F1 are directional
radials..... hence the ARROW on the tires ... <grin>
Old May 8, 2002 | 11:41 PM
LatemodelRacer2's Avatar
i jus rotated mine the other day at 3000. Ill see how it goes
Old May 9, 2002 | 03:35 AM
Boostin01L's Avatar
Mecca thanks man I've already done everything except the subs...decisions decisions
Old May 9, 2002 | 04:56 AM
EXCITED's Avatar
lug torque?
is a 150 # the torque spec on the 2001 L lugnuts?
