Chip install Question
Old May 6, 2002 | 04:55 PM
zbornac's Avatar
I bought a used chip and plan on installing it very soon. My only question is that I don't have a sponge to clean the contacts. So, I need to know what I can use to clean the contacts instead of the sponge. Any help would be GREATLY appreciated.
-Kimball
Old May 6, 2002 | 05:04 PM
S'CrewLoose's Avatar
Kimbal,
I guess all the questions have been answered right? The chip is the same code as your truck? You know how to reset the computer? You know how to install the chip? If so, you do not need a sponge, it is actually a piece of Scotch-Brite pad that is used to clean off the contacts, you can also use a razor blade or a piece of fine emory paper instead. Be very careful not to damage the contacts while cleaning.
Old May 6, 2002 | 05:07 PM
zbornac's Avatar
looks like I need to go get a scotch brite pad at wal mart.
Old May 6, 2002 | 05:15 PM
Lightning Bob's Avatar
This will help too.
Buying a used chip can be a risky propositon if you don't know exactly what model year and mods it was burned for. But here are all of the instructions you will need to acomplish the installation task.
http://teamjdm.com/id77.htm
Lightning Bob
Old May 6, 2002 | 05:16 PM
jagged edge's Avatar
Contact cleaner
You can use a green scotch brite pad which is what they give you when you buy new. I think you could use a extra fine sand paper but never emory paper because it is conductive as is steel wool. You may be able to get away with just a contact cleaner because the silicone was removed by the previous user of the chip.
Old May 6, 2002 | 05:17 PM
zbornac's Avatar
I know the chip is good as I have already sent it back to Sal for a re-burn. I have instructions for install, but not a scotch-brite pad. I appreciate everyones concerns, but I have already made sure on all of the other issues. You guys are always helpful past the point that is required, and I thank you all for that.
-Kimball
Old May 6, 2002 | 05:23 PM
SVTDAVE's Avatar
I used scotch bright pad and brake cleaner. Worked perfectly the first time i installed the chip.
