K&n
Old May 6, 2002 | 03:50 PM
Guapo's Avatar
K&n
K&N,
I've heard that in order to install a K&N filter, you need to have a chip... is this true?
I'm thinking about going with a K&N filter and new exhaust.
Thanks.
Old May 6, 2002 | 04:05 PM
DR.D's Avatar
I never heard that tho ' you might be right. I had a breather cap and KN panel and DIDN'T have a chip. I have stranger things happening now that I have a chip.
Old May 6, 2002 | 05:07 PM
2001SVT's Avatar
You should be ok without a chip with an exhaust and filter. The valve cover breather does require a chip however as the motor will run leaner.
Old May 6, 2002 | 05:16 PM
slapshot's Avatar
With just the K&N and exhaust, I wouldn't do a chip just for them. If you should order a chip in the future, make sure the tuner knows what you have added.
Old May 12, 2002 | 07:30 PM
todd abbott's Avatar
K&N
Guapo, I have an 01" Lightning with just a K&N panel filter, in stock trim and F1's at full pressure I ran a 13.525 at 100 and change, no chip needed
