C-notch help
Old May 6, 2002 | 01:12 PM
QKSILVR's Avatar
C-notch help
OK I just recieved my Western Chasis C-notch part# 2129. In the instructions there is no page 2 or 4. I am assuming the template was on here as well.
I am not going to cut blindly.
Jason
Old May 6, 2002 | 03:26 PM
DJY1's Avatar
I used no temp plate I just eyed balled it I placed the new C-section plate right above the rear end and cut from there. On one side I remmber there was a bolt that stuck out I had to plasma cut the hole bigger on the plate for the plate to fit over the bolt. The C-section kit looks very hard in the beginning, but is not that hard at all. Make sure you have a Plasma Cutter or a really good Salsaw with good blades, a good drill with really good bits because you will be drilling about 20 plus something holes.
If not call who ever sold you the kit and tell them you want a temp plate mailed to you.
djy
