6# pulley problem
Old May 5, 2002 | 11:23 AM
loosecannon's Avatar
6# pulley problem
Has anyone had problems w/ their 6# pulley and chip combo setting the ses light off? Mine kept on doing it and the diagnostics machine said that a lean condition was detected on both banks of my injectors. I ended up changing back to my 2# pulley and chip setup and the light hasn't come back. It looks like a chip problem, but I had been running the chip and pulley for about three weeks w/ no problems. Any input would be greatly appreciated. Thankyou, Jason
Old May 5, 2002 | 11:44 AM
Lightning#838's Avatar
Here's a shot, it might be your spark plugs. If your running on stock plugs with your 6# that might be what's doing it.
Old May 5, 2002 | 11:56 AM
Sorry, I forgot to put Denso IT 22's in my sig. They are only a coule months old.
Old May 5, 2002 | 12:11 PM
Odin's Wrath's Avatar
If your getting an SES light at WOT with the 6#, it could be that you need to replace your fuel pumps. They could either be not working correctly or not up to the task. It could just be that you need a reburn on your chip, however.
Old May 5, 2002 | 03:47 PM
We checked fuel pressure and got 32# at idle and 56# at wot. Book says 28 to 32#'s at idle so I think that looks normal. Can a chip go from running good to running bad? Only thing different from it running good to bad is new coils (all 8) and 160* stat, which it is supposed to be tuned for.
Old May 5, 2002 | 05:51 PM
Lightningquick's Avatar
160 stat could definrtly be the problem but I would think it would be running rich not lean with a 160......If the computer keeps the truck in a cold cycle too lond,you will get a ses light for sure. The reaso i know this for fact is I just put a thermostat in my 98 4cyl ranger today which was stuck open getting me 10 mpg for the last few weeks and a SES light!
Old May 5, 2002 | 08:37 PM
Shorty's Avatar
Recommend you contact JDM. They are probably on the road but I bet they can solve your problem.
Old May 6, 2002 | 11:17 AM
ttt
