28" tire with some bite
Old May 4, 2002 | 12:51 AM
JeffsLightning's Avatar
I'm looking at moving up from the 26"er's and need real world advice on a 28" tire. Either the Nitto drag radial or a Hoosier slick. What size Hoosiers are you guys going with? The 28x10.0 x16"? Do the Nittos hook as well as the Hoosiers? Let me know what has worked for you guys. 60' times would be helpful. Thanks for any advice... Jeff
Old May 4, 2002 | 05:08 PM
Guess nobody is running Nittos or Hoosiers....
Old May 4, 2002 | 05:18 PM
soap's Avatar
I don't have experience with either, I run ET Streets, but I guarantee that the Hoosier's will hook better than the Nitto's, not saying that the Nitto's won't hook but.......you are talking about 2 totally different tires.
--Joe
Old May 4, 2002 | 05:23 PM
Thanks soap. I guess my next question is what size Hoosiers are people running? The 28x10"x16"? Or is there a Hoosier D.O.T tire that will work for our L's?
Old May 4, 2002 | 05:25 PM
CHIKIN1's Avatar
Hoosier has DOT & "true" Slicks in the 28x10x16 I have a pair and have gotten a best of 1.73 60' with a stock stall converter!!!
Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
424HP/528ft.lbs @ Normal Temp. w/o N2O
JL Logocaps w/Keychain
JL 3# Lower Pulley
Sean Hyland 2# Upper Pulley
JDM Cold Air
JDM Boost Bypass
JDM/Accufab Throttle Body
JDM Longtubes w/ Silver-Bullet cat-back
JDM Cobra R pump
JDM Eletric Fan
JDM 2” Drop Shackles
PSP 4-Way Autologic Chip ( Tow, Street,Track, N20 )
PSP FactoryTech Valvebody
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
Nitrous Express 50-150 Kit ( Can’t decide which jets to use )
NGK / TR6’s ( .040gap )
Hoosier DOT’s 28 x 10 x 16
Old May 4, 2002 | 05:28 PM
What wheels are you using?
Old May 4, 2002 | 05:32 PM
CHIKIN1's Avatar
Just some EL-CHEAPO Vision 16x8.5's, but they're alot lighter than stock ones!!!!!Chikin@Charter.net
Black '01
Born on 5-3-01
#3603 of 6381
JL 3# Lower Pulley
JDM Cold Air
JDM Boost Bypass
JDM Cobra R pump
JDM Eletric Fan
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Truck-Traks
PSP Nitrous Plate
Old May 4, 2002 | 06:36 PM
StruckBy99's Avatar
Jeff
You should have tried my ET streets last night
It would have been an interesting comparison
Jason
