Jet Hot Coated vs. Stainless
Old May 3, 2002 | 09:05 AM
Brian Baskin's Avatar
Like was mentioned, SS headers dramatically increase the temperature underhood. I thought I was overheating the first few days afterwards. They also discolor quickly:
Ceramic headers keep in heat, and stay shiny, they don't discolor. But, they do eventually rust and pit. Ceramic headers also cost about $200-300 more than their SS equivalents.
Old Jul 16, 2002 | 01:57 PM
Galaxy's Avatar
So how about what DL said about getting SS headers coated on the outside only?
I am looking at the Edelbrock headers (SS with nickel/chrome coating) because of price and they look like a good piece, but want to get them coated if need be.
Old Jul 16, 2002 | 10:50 PM
Tim Skelton's Avatar
There is no logic to coating the headers on the outside only. Jet-Hot coats them inside and out for a reason--durability.
Any increased power from ceramic coatings is marginal at best. I would defy anyone to notice the difference. However, as mentioned elsewhere, the ceramic coatings do lower underhood temperatures, which is important with longtubes because of the increased pipe surface area.
For the ultimate setup, get stainless headers, send them to Jet-Hot, then wrap them with header wrap before installing. You might even get lower underhood temps than stock with such a setup.
Old Jul 16, 2002 | 11:30 PM
01 Red's Avatar
Originally posted by DL
Hey,
What about getting the SS headers and having them ceramic coated on the outside only?
This way, you have the best of both worlds. They will burn hotter inside the chambers then the mild steel ones (more power), You don't have to worry about them rusting, the engine area will be cooler, and hopefully they will generate more TRQ and HP than the ceramic coated mild steel ones.
I run SS headers on my Firehawk and a SC'd Grand Prix and I had them both coated - inside and out - by AirBorne Coatings in Conneticut. Keeps underhood temps down, keeps temp up in headers=small hp gains, and keeps them looking great. I've had the coated SS (SLP) headers in my Hawk for 5 years and they still look brand new. When I install headers in the L it'll be JDM SS and I'll have them coated in and out. Hope this helps.
Old Jul 17, 2002 | 10:17 AM
reality1's Avatar
Underhood temps do matter, look at where your S/C inlet is.
