Emergency Brake Light flashes.
Old Apr 28, 2002 | 11:38 PM
outrageous01's Avatar
Anyone else have this problem. My E brake light flashes when ever I step into it or if I hit a good bump. Does it have a loose wire or is it set up to close to the pedal, I have no clue.
Old Apr 28, 2002 | 11:44 PM
Crazyone's Avatar
Check your brake fluid, and ensure its full and that the lid is on tight, typically the brake light flashes when its low, or cap is not on tight.
Brandon
Old Apr 28, 2002 | 11:46 PM
That's all ok. It has to be in the wiring.
Old Apr 29, 2002 | 12:06 AM
Crazyone's Avatar
When you apply the brake does it stay on solid? Might be the contact switch on teh pedal also, which you can see if you look at the pedal assm. You can undo it and see if its stops, or sinc eit looks like tis a 01 you can simply take it to a dealer.
Brandon
