New option for T/B
New option for T/B
I just came across a great way to save $$ on a BABolt billet T/B. You can buy them without the TPS and without the linkage for $315 including freight. You use the TPS from the factory T/B (2 screws and it drops in). The linkage is a little trickier but not bad at all. With a small grinding wheel you grind off the tack-weld on the factory unit and tack it on to the new one. Everything else is included. Not exactly a bolt-on, but for very little effort you save some serious $$. This is on the brushed (machined) finish, not the polished. It is the real deal, same work of art with just a little assembly required.
