Intercooler temp
Old Apr 24, 2002 | 04:57 PM
frank2's Avatar
Intercooler temp
does the Intercooler pump run all thetime or is it set to a certain temp??I want to install a fan to help pull air thru but I don't know if its running all th time
Old Apr 24, 2002 | 05:58 PM
SMJayman's Avatar
Re: Intercooler temp
Running all the time, so far as I know...
Old Apr 24, 2002 | 10:28 PM
krummer's Avatar
Engine on/ pump on, engine off/pump off, adverage temp.
90/110' f, add bypass switch to run when engines off, helps reduce temp. 10' f in maybe 20 minutes, but your competing against motor temp.
Check out this post.
http://www.haloclub.com/forums/viewt...1510&forum=6&6
