K&N panel question?
Old Apr 21, 2002 | 02:31 AM
EXCITED's Avatar
Question K&N panel question?
Has anyone heard of the K&N panel filter (oil) being sucked onto your mass air flow sensor and damaging it
Old Apr 21, 2002 | 02:43 AM
Wantmorespeed's Avatar
Angry Yes!!
I recently battled my dealer to fix my problem of the engine idiling rough and dying. Dealer states that the mass air flow sensor was gummed up with oil from my filter. Luckily I have a good relationship with my dealer and they replaced it under my extended warranty.
Old Apr 21, 2002 | 05:15 AM
DR.D's Avatar
Nope. Didn't see that much oil on it for that to happen.
Old May 6, 2002 | 10:06 PM
Kipster's Avatar
Re: K&N panel question?
Yes and no!
A minute amount of oil does migrate to the MAS filament.
Over time, a coating will form on the sensor, causing a rough idle.
The MAS miscalculates the airflow rate and you'll run richer.
After a filter re-charge is the more common occurance (people putting too much oil on.
The filament can, however, be cleaned, carefully using a Q-tip and contact cleaner.
Old May 7, 2002 | 12:02 AM
captainoblivious's Avatar
I've never had that problem before. But I also barely oil the thing up.
It might not be a bad idea to clean the MAF out whenever you clean the TB.
