is it okay to patch a drag radial?
Old Apr 20, 2002 | 03:53 PM
clonetek's Avatar
my local track has that grey crushed rock in the pits to park on, and on my way up to the staging lanes, i must have run over a sharp piece. it put a small hole in the middle of the tire.
my question is, would it be safe to patch it and use again?
i am jobless right now, and can't afford to buy a new set of tires.
Old Apr 20, 2002 | 04:23 PM
'01ArrestMeRed's Avatar
Unhappy
I have a job and cannot afford to buy drag tires.
Personally, I wouldn't risk my neck and truck to a patched tire on a racetrack.
I got a sharp rock cut on one of my F1's. The tire shops will not patch it. It is maybe a 1/4" cut. They will not do it as of the liability involved......and it being a Z rated tire.
I'm running my spare right now...........until I can afford a new tire.
Rick
Old Apr 20, 2002 | 05:20 PM
Probleminfected's Avatar
i had two nails in my f1's and discount tires patched them up for me ????
Old Apr 20, 2002 | 05:54 PM
Lightningquick's Avatar
If you do a patch the right way,There will be no problem.I had patches in 2 of my f1s and never had a problem up to 140 and all...............Oops that was stupid...........but anyway,I dont see a problem if done correctly.
Old Apr 20, 2002 | 05:59 PM
Marvin's Avatar
I know on motorcycle tires that when you patch a tire (from the indise) that the tire manufacturers say the speed rating is dropped to 85mph.
On a personal note, I have run and seen many tires run over 85 that are patched with no failures.
I think the tire makers are just covering their butts.
Marvin
Old Apr 20, 2002 | 08:26 PM
i've been up to 140+ a good couple of times since i got the tires patched, i guess i would be dead if it blew, oh well no more scaring my friends
Old Apr 21, 2002 | 05:25 AM
clonetek's Avatar
well, this is a drag radial.. not the F1's..
the truck usually runs 103-105 thru the traps... i still dunno. this just sucks.
