Attn. Sal, Jim, or Johnny!
Old Apr 9, 2002 | 01:27 PM
TheSilverBullet's Avatar
Anybody know of alcohol injection applications on Gen2 Lightnings?
I'm looking for running an extra 6lbs. of boost with alcohol injection to reduce the chances of detonation...any thoughts?
i may consider doing interchangable pullies so i can have a street setup and a race setup...any ideas?
-Dan
Old Apr 9, 2002 | 01:53 PM
ttt
Old Apr 9, 2002 | 02:07 PM
Spike Engineering's Avatar
If you relocate the battery and replace it with a reservoir, then tap the bottom of BABolts power pipe (if you can get one) and no one will see it. A "small" system from the turbo buick guys will work regarding the pump and injector size. As far as tuners are concerned, you may want to contact Danny Swanson.
Spike
Old Apr 9, 2002 | 08:19 PM
LIGHTNINROD's Avatar
Smile Dan:
You may be overcomplicating things with alcohol injection.. I too worried about detonation and made the changes below.
Installing a 160*F thermostat in place of the 190*F 'stat and changing to NGK BR7EFs spark plugs will/may reduce the possibility of detonation. The BR7s are 'colder' than a Chicago blizzard and will misfire around town but they are inexpensive and run the 1/4 well. Denso Irridium plugs(IT24) should be as 'cold' but won't misfire. They cost upwards of $90 but I'm going to replace my BR7s with them soon.
Dan
Old Apr 9, 2002 | 08:36 PM
Re: Dan:
Originally posted by LIGHTNINROD
You may be overcomplicating things with alcohol injection.. I too worried about detonation and made the changes below. ...
What if you tune the chip for artificially higher octane while only using pump gas?
Spike
