Front Springs
Old Apr 10, 2002 | 10:05 AM
Chainsaw13's Avatar
From: Cuttin' Heads with Jack Butler at the CrossRoads!
I'm not sure if Autozone carries them. I would assume so, but you might want to call ahead. I don't believe there is a difference in the kits between a Lightning and a regular F150.
When you go to put the upper arm back in, instead of using the stock nuts/bolts you took out, put in the new cam bolts and torque to specs.
Bob
Old Apr 10, 2002 | 10:20 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
out of curiosity
what is the torque spec for the upper a-arm bolts?
Old Apr 10, 2002 | 10:28 AM
NakMan's Avatar
You don't need a spring compressor nor do you need a second jack if you have jack stands.
I did more or less what RTKILLA did, only I removed the swaybar end links and separated the top ball joint by banging on the spindle next to it with a ball peen hammer. Because I didn't remove the upper arm bolts, I didn't remove the wheel well liner.
You have to lower the arm quite a ways before the spring comes out. It's so well shrouded on both ends that I can hardly imagine a scenerio where it would fly out.
NakMan
Old Apr 10, 2002 | 10:38 AM
ASVTFordBoy's Avatar
Take a look at this thread. It was pretty easy this way.
https://www.f150online.com/forums/sh...threadid=62144
Old Apr 10, 2002 | 01:54 PM
Chainsaw13's Avatar
Speedin Bob, I knew someone was going to ask that. My Chilton's manual is at home so I won't be able to post the specs until tomorrow. Maybe someone else can chime in with the info.
Bob
Old Apr 11, 2002 | 09:43 AM
torque specs..
ttt
Old Apr 11, 2002 | 11:44 AM
phat150's Avatar
specs
Speedin Bob-
The torque spec for the upper control arm is 84 to 112 ft-lb.
Old Apr 12, 2002 | 07:43 AM
Chainsaw13's Avatar
Thanks Phat150. I forgot to look at my manual before coming into work yesterday.
Bob
Old Apr 12, 2002 | 09:30 AM
Thanks phat!!!
Old Apr 12, 2002 | 06:09 PM
phat150's Avatar
No problem.
