I need engine stats quick.........
Old Apr 4, 2002 | 03:57 AM
SVTPWR99's Avatar
Hi, I have a 99 Lightning and i'm trying to fill out this warranty card for my converter but i don't know all the info, could someone please help me?
Engine Cu. In.:
Cam Lift:
Dur:
Ctrs:
Differential Ratio:
Transmission:
thanx alot
Old Apr 4, 2002 | 03:59 AM
Boostin01L's Avatar
331
3:55
4r100
Old Apr 4, 2002 | 08:20 AM
ARTIE54's Avatar
Lightbulb
FOR THE CAM LIFT DURATION AND CENTERS TELL THEM ITS THE STOCK FACTORY CAMS IF YOU HAVE NOT CHANGED THEM. THEY ASK FOR THOSE SPECS BECAUSE DURATION AND CENTERS CAN RADICALY CHANGE IDLE SPEED AND VACUM IN MOTOR FOR INSTANCE A CAM WITH 320 DEGREES OF DURATION IS MORE OF A STICK SHIFT / LIGHTER WEIGHT CAR SET UP AND AS DURATION INCREASES IDLE SPEED HAS TO RISE DUE TO LITTLE OR NO VACUM AT IDLE=HIGHER STALL SPEED CONVERTER. ARTIE HOPE THIS HELPS
