Anyone know how to read spark plugs?
Old Mar 31, 2002 | 07:20 PM
Skank Dog's Avatar
I dont have pics of them yet, but my plugs (NGK TR6's) where black on the porcelain part and the electrode's where white. Some of the electrode's had a crusty brownish/white buildup on them and the one's that did had what I assume to be oil on the threads.
Can someone tell me whats going on in the engine by this description? Im gonna go pick up a new set of NGK's in the morning and change them out.
Old Mar 31, 2002 | 07:39 PM
LIGHTNINROD's Avatar
Skank:
From your description and after looking at my Haynes manual's inside rear cover, It sounds like you have 'carbon deposits'--"Dry, sooty deposits indcate a rich mixture--can cause hard-starting, mis-firing, or hesitation. Recommendations: Make sure the plug has the correct heat-range. Check for clogged air filter."
And, I would add--ask JDM about the a/f ratios--some are as rich as '11.1/1. You may be getting some of the residue from any octane booster you have used???
Dan
Old Mar 31, 2002 | 07:46 PM
Skank Dog's Avatar
Thumbs up
LIGHNINROD-Thanks! Are your BR7E's a colder or hotter plug than the TR6's? I may check into the TR5's too if they are hotter.
Speaking of residue, I have been using a gallon of Toluene to 1/2 tank of Texaco 93 to stop detonation problems. Truck still runs and idles smooth, just thought Id check the plugs and thats what I found.
Thanks again!
Old Mar 31, 2002 | 09:18 PM
Skankdog:
The BR7EFs are 'colder' than a coal miner's hemorrhoids ! When I change again, I'm going to the Denso Irridiums. The 7s foul-out and misfire in my eng. around town--at low rpms. Now, at the track--they're fine but others are getting better results with the Densos.
The TR5s are 'hotter' than the 6s but I think you need at least the heat-range of the 6s with the extra boost you have. Better fouling plugs than a detonation situation. You ought to think about the Densos unless you're one of those 1 hr. plug changers--LOL
Dan
Old Mar 31, 2002 | 09:19 PM
awhittle's Avatar
Talk to Jim. Something is causing it to run way too rich. I went to a tr5 to cure a rough idle but the tr6's came out white.
Hope this helps
Andy
Old Mar 31, 2002 | 11:08 PM
Skank Dog's Avatar
LIGHTNINROD- Ive thought about the Densos. Do you know which one's have the same heat range as the TR6's? Ive seen IT20,22,and 24's.
awhittle-I think Ill wait and catch Jim @ FFW here in Ennis and let him check my chip. I just hate knowing I cant drive it until he sends me my chip back after a reburn!
Old Mar 31, 2002 | 11:17 PM
Captain_Nemo's Avatar
This site might be helpful
http://www.ngksparkplugs.com/techinf...s/overview.asp
