Keyless Entry Question????
Old Mar 29, 2002 | 03:12 PM
Koochie Krook's Avatar
I have lost my paperwork that shows door locking, and unlocking codes. Does anyone have them. I know my five digit security code. Thanks
Old Mar 29, 2002 | 03:23 PM
cteselle's Avatar
from http://www.svtlightnings.com/svt/key...ad_install.htm:
How to set your own personal entry code or Open Both doors or disable autolock
IMPORTANT: Every step outlined in every procedure below must be done within five(5) seconds of the previous step.
Programming your own personal entry code
Enter the factory-set code (keypad will illuminate when first digit is pressed).
Press the 1/2 control.
Enter your personal 5-digit code.
Your personal code does not replace the factory-set code. You can use either code to unlock your vehicle. Each time you set a new personal code the module will erase the previous one in favor of the new code.
Deprogramming (erasing) your own personal code and leaving only the factory-set
Enter the factory-set code.
Press the 7/8 and 9/0 controls at the same time.
The system will now only respond to the factory-set code.
Unlocking the driver's door (also disarms the perimeter alarm system)
Enter either the factory-set code or the personal code. The interior lights will illuminate as soon as the first valid digit is pressed.
Unlocking all doors - Unlock the driver's door then press the 3/4 control.
Locking the doors (also arms the perimeter alarm system) -Press 7/8 and 9/0 controls at the same time. The 5-digit code does not have to be entered.
Deactivating/Activating Autolock - Enter the five (5) digit code.
Press and release the 3/4 control while holding the 7/8 control, then release 7/8.
