anyone with these in their Ls
Old Mar 27, 2002 | 09:45 PM
kitbuf's Avatar
Wink check this out
NGK TR7s
If so, how much extra boost (#pulley) are you running to see the need for these plugs. I'm getting ready to put in a 4#pulley and I believe I'm going to be using the 7s instead of the 6s. Opinions?
Old Mar 27, 2002 | 10:03 PM
Lightning Boy's Avatar
In my opinion, I think the 7's are too cold and would foul onder daily driveing.
But I would highly recomind that you contact your tuner and see what his opinion would be.
Old Mar 27, 2002 | 10:22 PM
Don's Bolt's Avatar
I would go with the TR5 or TR6
I run the TR6 with 3.5 extra boost and they work great for me.
Old Mar 27, 2002 | 11:04 PM
ASVTFordBoy's Avatar
I have the BR7's with my 4# pulley, and they are doing good. I lost a little throttle response, but other than that no problems with fouling.
Old Mar 28, 2002 | 11:15 AM
beefcake's Avatar
sal recommended i go with the 7's even though i daily drive.
that was when i had the 4, now that i have the 6 for sure
i just made a 1000 mile trip each way to florida and back with no problems 3 weeks ago and then just ran my best times this past weekend
Old Mar 28, 2002 | 09:39 PM
kitbuf's Avatar
keep those opinions coming
ttt
Especially opinions on running a 4# pulley or more.
Would also like to know part# for Ngk tr7 and if you know part# for belt for 4lb pulley. I believe napa # for belt is 080670 but is there any others you might know other than napa. Thanks.
Old Mar 29, 2002 | 02:11 PM
kitbuf's Avatar
Do you know the part# for the 7s
Old Mar 29, 2002 | 02:34 PM
beefcake's Avatar
http://www.powersurgeperformance.net...at=Spark+Plugs
Old Mar 29, 2002 | 03:24 PM
usahooters's Avatar
The 7 is a real cold plug, Your not going to have a big detonation problem now that the air is getting less dense with summer coming. I run a NGK TR 5 gapped down to .038 and its fine. A TR 6 lasted about two weeks of everyday driving before I fouled them out and I run a 6# pulley. I wouldn't go with a 7 unless your just going to be racing. I don't know the belt part number for the 4# but I do know that the NAPA 8 rib belt 68" long is the one that you want for a JL pulley.
