Hotchkis 2" *Steel* Drop Leaf Springs
Old Mar 28, 2002 | 10:10 PM
Chikenears's Avatar
Question Hotchkis 2" Drop Leaf Springs *Steel*
Who sells these springs? I would rather buy springs than change the front hanger! Not the fiberglass spring, the steel one that Hotchkis makes that has a two inch drop.
Old Mar 28, 2002 | 11:24 PM
speeder's Avatar
Thumbs up Hotchkis Springs
Chikenears
Go to www.hotchkis.net , you can order the springs directly from them. I had there 2/3 lowering springs on my 01 f150 supercab and had no problems at all with there parts. There lowering kits are a bit over priced, but the quality of there parts is worth it.
I hope this helps.
Larry.
Old Mar 28, 2002 | 11:48 PM
captainoblivious's Avatar
I got mine from Mark@LFP, if I'm not mistaken JDM also sells them.
Since the Hotchkis rear leafs are stiffer then stock leafs, you may also want to look into better shocks. The hotchkis will overpower the 99'-00' shocks, and the 01' bilstien shocks will hold out a little better.
Old Mar 28, 2002 | 11:57 PM
Chikenears's Avatar
Speeder,
I went to Hotchkis.org and their price was higher than Mark's at LFP. Thanks
captainoblivious,
I just ordered them from Mark. I already have some shocks, Doetsch Nitro's. Thanks
Old Mar 29, 2002 | 12:47 AM
JeffsLightning's Avatar
Re: Hotchkis 2" Drop Leaf Springs *Steel*
What's wrong with the glass springs? They are allot lighter and also lower the back by 2"...
Old Mar 29, 2002 | 12:59 AM
NOSTROMO
Guest
Posts: n/a
Chicken I WOuldnt run those Doetsch Nitros with the Hotchkis springs. The spring rates will overpower them and will probably bounce around, as Captain stated.
Lowering shocks from Belltech, Doetsch Tech are absolutely horrible...In fact most of those shocks are OEM, cut, and not revalved to accomodate your setup.....I have used both and can give you an idea of what you are in for.
Stay with the Bilsteins
Old Mar 29, 2002 | 07:17 AM
HANKFAN's Avatar
I got mine from Summit for $281.00 delivered!!
Old Mar 29, 2002 | 08:08 AM
Chikenears's Avatar
JeffsLightning,
Call me old fashioned, if you will, but I'm not going to ride on a fiberglass spring. Glass might be OK for body panels and such. . .
NOSTROMO,
I have two sets of shocks to try. I'll find the best setup after I get the truck lowered and aligned. Thanks
HANKFAN,
Marks price was $294 shipped, not too bad and I like to support the vendors if possible.
HANK, where did you get that Supercharged emblem on your tailgate? I like that! Thanks
Tim
Old Mar 29, 2002 | 08:50 AM
Ebbsnflows's Avatar
For those that have these installed.....did you get a FULL 2" drop? More? Less? Just wanna know if the specs are accurate.
Old Mar 29, 2002 | 09:13 AM
Chikenears's Avatar
SVTRobG told me that with his Hotchkis springs and Bell Tech shackles he got only three inches of lowering. That is what I'm after. He has a different setup now, he went even lower by adding front spring hangers and going back to stock shackles.
Maybe someone else, that has them, will post their findings.
Old Mar 29, 2002 | 09:32 AM
KGM's Avatar
KGM
Hey don't be chicken...Vettes have been on glass springs for years. Look at the weight savings.
Old Mar 29, 2002 | 11:22 AM
ebbs - check out this thread : http://www.nloc.net/forum/showthread.php?threadid=13525
Old Mar 29, 2002 | 11:25 AM
SVTRobG's Avatar
Vettes aren't 4,700+ lbs. and don't put down 450lb.ft. of torque stock. I want to see these 'glass springs perform at the track this year and if people don't brake them I might consider a set.
Replacing your stock leafs for the Hotchkis leafs you will get exactly 2 inches of drop and save a little weight too.
Old Mar 29, 2002 | 02:34 PM
DaveRed99's Avatar
this is what i want to do ....
i want to go with the Hotchkis leafs for the 2 inches and get a spring for the from that will lower me 1"....... i think that it will make the truck alot more nimble....
Old Mar 29, 2002 | 07:27 PM
HANKFAN's Avatar
Chikenears- That's not a super charged emblem on my tailgate but rather an NOS emblem.
