Help getting hangers off
Old Mar 27, 2002 | 02:17 PM
QKSILVR's Avatar
Unhappy Help getting hangers off
Man these are a pain. I have a grinder/cutter and got the heads off the rivets. I tried to use a punch and hammer to knock it through with no luck. I have only done two of them. Ran out of grinding discs and have now way to get to the store. So I tried to punch them out.
Should I get the other two off and then pull the hanger off. Then hit the rivets since they are sticking out? I would think this would be easier.
I am taking wife to work tomorrow, so should I buy a impact hammer??
Old Mar 27, 2002 | 02:36 PM
Chikenears's Avatar
Drill a hole through them and they will come out easier. Watch out for the gas lines and tank.
Old Mar 27, 2002 | 02:42 PM
Chikenears's Avatar
If you do that, they will tend to flatten out and be even harder to get off.
Old Mar 27, 2002 | 02:55 PM
ICULOKN's Avatar
Cut all the heads off, Pull the hanger off, Cut them flush with the frame, then use a air hammer with a punch insert to knock them through the frame. Its a pain in the butt but it can be done. Dont worry if you grind your frame cutting them flush, it wont hurt anything....
