New upper intake
Old Mar 24, 2002 | 06:44 PM
Silver-Bolt's Avatar
New upper intake
Finally got around to installing my new Extrude-Honed upper intake adaptor today. Will be back on the dyno soon. Stay tuned for the results. Should flow much better and also reduce the air temp.
Just realized I can't attach a photo. Will try and post one in a few.
Old Mar 24, 2002 | 06:56 PM
See if this works.
https://www.f150online.com/galleries...y.cfm?gnum=985
Old Mar 24, 2002 | 07:04 PM
TheHylandr's Avatar
Thumbs up
It works...
Looks sweet...can't wait to see the difference it makes.
Old Mar 24, 2002 | 07:18 PM
Thor01's Avatar
It's good for a 11 hp. If you want the best results be sure to port match it to a single blade t-body.
Old Mar 24, 2002 | 07:26 PM
Thor,
I did do the port match.
Old Mar 24, 2002 | 07:49 PM
Thor01's Avatar
Thumbs up
Good! You'll get the most out of it! I have data from Extrudehone on this part! Dyno data that is! It's on a 2000 L. You might get a little more. I don't know if it was dyno'd with a single blade and port matched. I'll get those specifics when I talk to rick. Hope you get good numbers.
Old Mar 24, 2002 | 08:00 PM
TheHylandr's Avatar
How can I get ahold of them...do they have a website?
Old Mar 24, 2002 | 08:06 PM
Thor01's Avatar
It's www.extrudehone.com
Old Mar 24, 2002 | 08:11 PM
TheHylandr's Avatar
Thumbs up
Thanks Thor
Old Mar 24, 2002 | 08:33 PM
JBLsilver01's Avatar
Do you have a smooth intake 'boot' to go along with it? Its seems like one of the tuners or companies would make a smooth one by now. The big bumpy-ribbed one seems like it would obstruct smooth air flow into the TB - or am I wrong?
Old Mar 24, 2002 | 09:38 PM
PFA's Avatar
PFA
What is the cost of extruning it? Or did you get it from a Speed shop?
Old Mar 24, 2002 | 09:50 PM
JBL, at this time I still have the factory boot. Hope to change that soon.
At this time this is not a "production" part. At some point in the future that might happen. I am acting as the test mule. I received the part with the honing process done. I then did the match porting with the T/B and a little polishing on the outside.
If anu of you have ever had your factory intake off you know how rough they are. The port matching from the factory is terrible. This process smoothes the interior to a very fine uniform finish. It should flow better and have lower intake temps.
Schedule permitting I will go back on the dyno this week.
