What is this?
Originally posted by kylightning
quote:
Originally posted by clonetek
ahh.. it looks like you have captured a nice specimen of swapablius pullidon of the lower family.
that looks rare, you have it mounted.
So Tim,
I hope you didn't kill the folks in the photo while you were out hunting fuzzballs!!! If you're here that means you're not in the garage installing, or somethin'.......waaaassssuppp wid dat??
Originally posted by SLVRLTNG
So Tim,
So Tim,
No, I couldn't kill an ant. Those folks are alive and kicking my *** everyday!
Good,
have 'em kick it once or twice for me, can't keep up with the sHoElAcE worken chiken with ears....
How long does it take to cook dem "chikenears anyhow?" we need to know, weather's gettin better for outdoor kookin...or somethin.........
just ask you know who for me.......JR
You need another pulley belt (#25-080680 at NAPA) or to modify your tensioner by breaking off the nub that prevents it from moving further over. I haven't done the tensioner mod, so I can't tell you exactly how to do it.
Good,
How long does it take to cook dem "chikenears anyhow?" we need to know, weather's gettin better for outdoor kookin...or somethin.........just ask you know who for me.......JR
Good,
I just got a reply from Justin at JDM. He said that the stock belt works with the pulley.
How long to cook chikenears? Hell, I don't know! I'm the one with the ears, I can't cook em I might need to hear with em!
LOL
Odin's and Silver-Bolt,
You have two different part numbers.
Odin, is your belt number for a 4# pulley? I'm just trying to clarifiy this a little. I appreciate the help.
Tim
Tim
I've seen both numbers used actually. I've seen posts of people using the 080680 on both 2 and 4# pulleys without a problem. Myself, I'd compare the two at NAPA and get the shortest one to keep things tight. I got the stock belt to work for me on my set-up, but I'm using a 2# upper and lower. It was still rough to do.
Roger
Roger
If you elect to use the stock belt you will absolutely have to remove the infamous "nub" from the tensioner. To do it you just need to move the coolant reservoir out of the way, remove the upper left bolt from the tensioner assembly and then I use a small hand hacksaw with a metal blade to cut the dreaded "nub" off (much cleaner and less chance of screwing something up than using a big pry bar to break it off)...viola, tensioner circumcision complete.
i just used a big flathead screwdriver to break it off..
not really sure where it went.. i think it broke the sound barrier as it screamed off to nub heaven.
i was kinda sad too.. i wanted to put it under my pillow that night, and see what the pulley fairy would bring me... or something.
Originally posted by Chikenears
I will hang it with all my other wild animals that I've killed!
So, which one is you in the mantle photo?
Bob
Originally posted by Speedin Bob
You forgot the foo foo aerobic weight 'catch.'
Bob
Bob
he's the fuzzy one on the right of that pulley thang...or sumthin'...JR
