How long for these installs?? help
Old Mar 23, 2002 | 07:40 AM
lihtning's Avatar
I am about to pay someone for installing the following parts in my 2000L and I am just wondering how many hours are generally required for these. Nay help please and thanks.:
eibach front springs?
rear shackles?
NGK TR5 plugs?
3.73 gears?
lower 3lb pulley?
Thanks for all your help!
Old Mar 23, 2002 | 07:45 AM
Don's Bolt's Avatar
Re: How long for these installs?? help
eibach front springs? 1-1.5 hours, then you will need a allignment
rear shackles? 15-20 min
NGK TR5 plugs? 1-2 hours
3.73 gears? Don't know
lower 3lb pulley? 30-45 min.
Old Mar 23, 2002 | 09:44 AM
poweredbySVT's Avatar
rear shackles?
Paid $100 here in S. FLA for FRP Front Springs and Rear Shackles
*PLUS alignment
NGK TR5 plugs?
??? Dont know had my dealer install as a favor!
3.73 gears?
Going rate down here is about $150-175
lower 3lb pulley?
*Bought lunch for my Friend....it was a quick job
Old Mar 24, 2002 | 10:32 AM
lihtning's Avatar
Thanks for the help guys! Anyone else with big differences in the above times are welcomed. Thanks for all the help.
Old Mar 24, 2002 | 10:41 AM
Odin's Wrath's Avatar
On the plugs, I called around before doing them myself. Every place I talked to quoted three hours of book labor. Unless you have someone who charges you actual labor as a favor, you'll likely be charged full book regardless. About $180.00 should be expected.
Rear shackles cost me $50.00.
Old Mar 24, 2002 | 01:26 PM
2Cool's Avatar
Rear shackles take 20 minutes with a floor jack and jack-stands, first time, likely faster with practice. So $50 would be steep...
Gears around here run $200 or so for install.
No clue on plugs yet...
