@#$%*&!@#$ spark plug swap
grrrrrr.... stoopid rubber boot on coil packs... cant buy the @#%%^# things by themselves.. now i have a extra coil pack.
anyone out there got a lead on extra rubber boots for coil packs?
anyway, put 3 denso's in today... broke one rubber boot. (cost $40)
the stock plugs look pretty good so far.. i'll post pics later..
don: it popped off at first, but my stupid *** tried to use a pair of pliers to get it out..
now i know to use a small screwdriver to break it loose from around the plug..
heres the boot that got stuck...
a couple more were stuck today, but i used a piece of a antenna off of a K-40 and some silicon grease to poke around inside the boot. they popped off after that. it broke the seal that the boot had on the ceramic part of the plug.
I got a set of Denso's coming also. But it was my understanding that the gap should be .040 not .038. Did you go with what they where out of the box for fear of breaking a tip trying to gap? That's a real possiblity with these plugs or so I hear
Iam not sure which ones Iam getting, I'll just take what Sal sends
patience
and check out:
http://captainoblivious.tripod.com/truck/plugs.html
at the bottom of the page is also a links to Chuck's page which has great info on the plug swaps.
and check out:
