Lean Code
Old Mar 22, 2002 | 05:32 PM
HIGH ROLLER's Avatar
Unhappy Lean Code
Guys,
I went to the dyno today and right before i got there my check engine light came on so they scanned it and it came up a lean code on bank 1, i reset the battery to clear the computer and it went off but still comes on after about 30min. of driving with a chip in or without a chip and it still did it.I was driving normal cruising speeds the whole time when it comes on.What might be causing this code to come up and how to fix the problem.My air-fuel is still in the safe zone and my tips are nice and black! Any info would be appreciated!
Matt
Old Mar 22, 2002 | 05:35 PM
Lightning Boy's Avatar
O2 sensor could be bad, cloged fuel filter, dirty MAF... those things right off the top of my head.
Old Mar 22, 2002 | 05:50 PM
lightning Jeff's Avatar
Matt, E-mail me
Jeff
Old Mar 22, 2002 | 05:53 PM
soap's Avatar
Well I know the fuel filter idea is gone...........he just changed it.
Talk to ya later tonight Matt.........BTW, I got some goodies today Check my sig..notice any updates.
--Joe
Old Mar 22, 2002 | 06:05 PM
WrongdayJ's Avatar
Lean codes can be caused by alot of things.
O2 sensor age/wear, injectors, fuel filters, fuel pumps, pressure regulators, MAF sensors, the list goes on. . .
Do you have an A/F ratio gage tapped into your factory sensor's SIG_RTN wire? If so, corrosion may be effecting your computer's signal/tuning. Don't laugh. . .I've seen this happen, and verified that indeed tapping into this wire can and will screw things up down the road. That's why I don't ever recommend people tapping this wire for the signal. Run another sensor if you want the A/F gage to avoid messing up your vehicles.
In the old days (EEC-IV) there was a cylinder balance test you could perform at home. I don't know if EEC-V with the OBD-II will let you perform it. I know the dealer techs can.
Good luck,
Old Mar 22, 2002 | 06:06 PM
LightningTuner's Avatar
Matt, check the gaskets on your long tubes to the heads. If one is leaking, it will set that code.
Old Mar 22, 2002 | 06:12 PM
ICULOKN's Avatar
So many things on these computer controled vehicles to check!!
Im glad we all share info or some of us would be paying ou the A$$ for checkups....
Old Mar 22, 2002 | 06:34 PM
Thanks guys for all your input much appreciated!
Jeff,
You have mail!
Joe,
Do you need my help to install it!
Sal,
I will mention that to my ford buddy!
Matt
Old Mar 22, 2002 | 08:43 PM
Silver-Bolt's Avatar
Matt,
If you are running the breather cap, that has been known to throw a lean code.
