5w30 or 10w 30 oil?
Old Mar 22, 2002 | 05:01 PM
hugo blk lytn's Avatar
5w30 or 10w 30 oil?
what's the difference? i usually buy 5w30 but i ordered some order and they sent me 10 w 30. should i just put that in my truck or does it make a big difference. my truck has 11,000 miles.
its royal purple synthetic oil.
Old Mar 22, 2002 | 05:27 PM
KGM's Avatar
KGM
Dump it in. 26K and never been in the shop.
Old Mar 22, 2002 | 05:42 PM
FRITZ's Avatar
Where can i order some of that brand of oil ?
FRITZ, Stock Silver 2001 "L" BaBolt's s/s tips
Old Mar 22, 2002 | 06:16 PM
DB's Avatar
DB
www.jegs.com
Old Mar 22, 2002 | 06:40 PM
Spade$'s Avatar
10 w 30 is better protection
Old Mar 22, 2002 | 07:38 PM
snoopy's Avatar
Spade$: Huh? Do you mean protection on cold starts, or in terms of longevity of the oil. Please explain.
Here is what I think:
The first number is the cold viscosity. A 5 weight would flow more easily that a 10. I would think a 5 would be more easily pumped to the top end on a cold startup.
The second, "w" means it's a multigrade, if I remember correctly.
The third, "30" in both cases here, is the warmed-up "hot" viscosity. Both would have the same here.
The spread between the first and last numbers is an indication of the amount of the fragile long-chain viscosity index improvers added to the formulation. A 5-30 has had more of these added, and is more suspectible to breakdown than a 10-30. The 5-30 base stock would break down (suffer viscosity reduction) more quickly than a 10-30.
Old Mar 23, 2002 | 11:52 AM
dboat's Avatar
hugo,
if you come here often enough, you will see that there are a wide variety of opinions on this topic. My opinion is that you use what you were sent. Its Spring and you dont live in the Great White North so cold startup shouldnt be a huge issue.. I run 5W30 Mobil 1 and am happy with it...
dboat
Old Mar 23, 2002 | 12:18 PM
Chikenears's Avatar
5W 30
Old Mar 23, 2002 | 05:38 PM
LIGHTNINROD's Avatar
23,800 miles...............
Royal Purple #11(5W20) Racing oil. It's been 'red-lined' many times too as well as driven daily.
Dan
Old Mar 23, 2002 | 11:57 PM
thanks, i think i'll just dump it in and see if there's any difference. if i notice something different i'll be sure to post it.
hugo
Old Mar 24, 2002 | 12:13 AM
RA6870's Avatar
Exclamation AMSOIL
Use an Amsoil 5w-20 or a 5w-30 its a better synthetic and its cheaper than royal purple!! I have 20,000 on my L and 300,000+ on my work truck with Amsoil and never any problems!!!Just my .02 cents worth!!
